KZ1300 turbo on ebay
- tjhiggin
08 Nov 2007 07:00
T.J. in Huntsville, Alabama
1983 KZ1100-A3, 1974 Honda CB550-4
Previous bikes: CB100, TS125, CB175, KZ400, CB500-4
- Mcdroid
- Gone Kwackers
Re: KZ1300 turbo on ebay
08 Nov 2007 07:05
This is atleast the second time the seller has listed this bike...it think it is a bit overpriced.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- Bluemeanie
08 Nov 2007 07:45
A bit over priced? I would not think bike would be worth much more than $5000? It is a very interesting bike, most likly scary fast! But for $15,000 you could buy 2 new bikes or 10 old KZ'z with a lot of change left over for parts!! :woohoo:
Post edited by: Bluemeanie, at: 2007/11/08 10:50
- otakar
08 Nov 2007 11:09
I have been working on KZ1300s since I bought mine in 1979. And I see a problem with that ADD. He claims it is a 1420cc bike. Well if he is using stock sleeves they are 66.75mm in OD at the smallest section which is in the three "O" ring grooves and the lower skirt. Well, at a 1420 the pistons are 65mm. That would make the sleeves .875 mm thick. That is .034". I would not sit on that bike being worried that it will come apart. Custom sleeves are $1400. I had to custom engineer them and had them cut. The amount of machine work which must be done to fit them is also unbelievable, due to tha 4 different steps and flanges in the cylinder block. Not to mention the "O" ring grooves. At that point you might as well go to the 66mm piston from the GPZ750 and make it a 1478. This is what I am doing and I would not dare to put a turbo on it. This all is avery expensive propposition.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- dannyg40
08 Nov 2007 13:33
Bluemeanie wrote:
Or a brand new Hyabusa and have about $4000 left over.
A bit over priced? I would not think bike would be worth much more than $5000? It is a very interesting bike, most likly scary fast! But for $15,000 you could buy 2 new bikes or 10 old KZ'z with a lot of change left over for parts!! :woohoo:<br><br>Post edited by: Bluemeanie, at: 2007/11/08 10:50
- Night_Train01
08 Nov 2007 15:24
I agree...... maybe in the $5000 range......mods like that are not for everyone.
- jjdwoodman
- Live free, or die.
08 Nov 2007 17:03
Totally agree! I know I've seen it listed twice, and I think maybe the guy's delusional.:huh:
77 650b
81 550 Mostly there
83 ZN1300 Voyager
81 550 Mostly there
83 ZN1300 Voyager
