engine polishing
- hydrolazer
engine polishing
27 Oct 2007 18:03
im going to try and get ltd rider to tell us how he got his engine to look so darned good,,,,,ltd rider if you please....
\'79 kaw 1000 ltd
- z1rick
Re: engine polishing
28 Oct 2007 19:35
I am jealous of his bike. It looks so good, even up close,
Anaheim CA
1999 KZ 100P
1974 Z1 900 Project
1977 (2) KZ 650 projects
1999 KZ 100P
1974 Z1 900 Project
- ltdrider
29 Oct 2007 09:31
Thanks for the kind words.
Lots of members have done some awesome work on their motors, polished to a mirror finish.
I wanted my motor to look like new stock, like it would have looked on the showroom floor. And they weren't mirror-shiny back then. So my motor's nothing like the one pictured at the top of this page.
The cast aluminum surfaces get rubbed with a scotchbrite pad (green) and Mothers Metal Polish. Get in-between the fins by folding the scotchbrite pad to fit. Buff it off with a soft cloth. Use a pencil or popcycle stick to force the buffing cloth between the fins.
The machined aluminum surfaces get rubbed with Mr. Buffer on a soft cloth, then buff it off with a clean soft cloth. It leaves some kind of surface residue that keeps it shiny for months.
After that, just keep the oil and grime off it with Simple Green and rinse with water. The less your motor leaks, the cleaner it will stay.
A fridge with cold beer, a stool, and some good tunes, and you can make an afternoon of it.
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
Greensboro, NC
- Norseman
29 Oct 2007 12:25
ltd, I'm assuming you first removed all the clear coat that was on the engine originally? I tried your method on mine, and it didn't make a lick of difference because of the remnants of some type of coating. How would one remove this substance - paint stripper?
- RonKZ650
29 Oct 2007 12:52
None of my motorcycles had any coating except the 1974 H2. The rest of them, you can polish real nice by hand.
- ltdrider
29 Oct 2007 12:53
Norseman wrote:
Oh yeah... don't forget to remove the clear coat! :pinch:
I used wet sandpaper on the machined (smooth) surfaces. Start with 600 grit, sand in one direction. Go to 800, and sand in the perpendicular direction. Then go to 1200 in the other direction. If your clearcoat was like mine (blistered), it'll come right off. You can do the same on your fork lowers... they'll buff out shiney!
I used a wire brush and coars steel wool on the cast surfaces.
I've never re-applied the clear coat after polishing because the shine is pretty easy to maintain.
Greensboro, NC
Greensboro, NC
- RonKZ650
29 Oct 2007 14:08
Interesting, none of mine had clearcoat. Forks, yes. Engine, no.
- ltdrider
29 Oct 2007 15:28
I thought mine was clearcoated. Had like a yellow film on it. Wet sanding removed it.
Greensboro, NC
Greensboro, NC
- hydrolazer
29 Oct 2007 17:00
thanks for a fast reply ltd rider...i rubbed my covers with mothers and the cast parts with the green scotch brite pads,with little effort i can see a huge difference,,,thanks for the tips
\'79 kaw 1000 ltd
- hydrolazer
29 Oct 2007 17:08
\'79 kaw 1000 ltd
- hydrolazer
29 Oct 2007 17:09
\'79 kaw 1000 ltd
