OK you KZ650 freaks... What is this bike???
- dreamsofaz1r
07 Oct 2007 19:23
Well, here is a piof the daily rider, a KZ650! HOWEVER, it is not as it appears, so you will REALLY need to look closely to figure out what 3 bikes this is made from!
- dreamsofaz1r
- dreamsofaz1r
Re: OK you KZ650 freaks... What is this bike???
07 Oct 2007 19:26
If you really know your 650's, you can spot everything that gives what is what away.
BTW, Melvis is not allowed to play, he used to own the bike(before this was done to it though).
- flht1997
07 Oct 2007 20:09
arg.....1976 for the from master cylinder, the right side cover has the cut out for a rear disc brake master cylinder, but you have a rear drum from a C? model, and the rear tail light is CSR? and the seat LTD?
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
89' BMW R100RT
06' KLR650
- dreamsofaz1r
07 Oct 2007 20:14
flht1997 wrote:
Ohhhh, close on some of the things. The C model's had mags with disk brakes, so the rear is not from a C model.
You are right about the mastery cylinder, it is from a 77(76 made 77) 650.
Light is original to bike(majority of the bike is original actually) and the seat is a custom cut foam job and recover so not really an LTD seat.
- kawsakiman
07 Oct 2007 20:36
sidecover emblems are from a 77 650.
no rear " ducktail" not 77
forks look either gpz or from a 79.
am i close?
am i close?
- dreamsofaz1r
07 Oct 2007 20:46
kawsakiman wrote:
Sidecovers are correct.
There is a rear ducktail, just isnt on.
Wrong on the forks.
Forks are original to the base bike, which is a 650, but what model and what year, and what in the pics gives it away to know what year and model???
am i close?
Wrong on the forks.
- moto_jojo
07 Oct 2007 23:40
Hmmm, Looks to be a 16 inch rear. maybe it's part SR? or ltd- by the wheels.
mjj
mjj
- jjdwoodman
- Live free, or die.
07 Oct 2007 23:49
I'd say a 77 b1 with added caliper and front wheel from a c or d, and a rear drum wheel off a 550. seat looks to be from an ltd.
77 650b
81 550 Mostly there
83 ZN1300 Voyager
81 550 Mostly there
83 ZN1300 Voyager
- dreamsofaz1r
- dreamsofaz1r
08 Oct 2007 01:38
jjdwoodman wrote:
Right on the money, other than the seat being a recovered B model seat.
it IS a 77, and you can tell by the calipers being on the front side of the forks and the round front master cylinder.
It IS a B model, and you can tell that because the B model had a drum back wheel, not disk.
It is a D model front wheel and calipers.
It is a 550 Rear 16 inch drum brake mag wheel.
You Sir, know your KZ's.
- flht1997
08 Oct 2007 09:51
was there a 650 that had a rear drum alloy rim? could have sworn i have seen them. or for that matter a 650 with a rear spoke disk brake?
Post edited by: flht1997, at: 2007/10/08 12:54
Matt Milwaukee, WI
89' BMW R100RT
06' KLR650
89' BMW R100RT
06' KLR650
