05 r6 rear set conversion for 77 kz650d
  • infinitexsound
  • infinitexsound's Avatar Topic Author
06 Oct 2007 03:27
#174865
i came across a good deal for a complete 05 R6 rear set.just wondering if anyone has did this conversion. i searched and have seen that people have modified they're stock components or purchased a gsxr rear set. id like to know if anyone has attempted this task.
  • hardr0ck68
  • hardr0ck68's Avatar
  • Who put the what in the where?
Re: 05 r6 rear set conversion for 77 kz650d
06 Oct 2007 06:15
#174872
the r6 runs the shift rod over the shifter, most people sue other rear sets that run the shift rod down under the motor. I looked at r6 rear sets bu when i saw them on a bike i thought that it would be to difficult to convert.
Let us know how it works for you!!
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
06 Oct 2007 08:57
#174883
I used the '04 GSXR600 and found them an easy install on my 650.
Being over or under the shifter has worked for others. When on top, the shift pattern will change to one up, four down. Takes a little while to get used to.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
06 Oct 2007 09:02
#174884
This post: Rear sets has some pix of the GSXR and ZX6 setup with the shift linkage above. Should help you to picture how to go about it.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
  • infinitexsound
06 Oct 2007 17:06
#174966
thanks guys.. seems like running a suk rear set is the way to go since its already tried and true... ill just have to pass up the r6 set...ill post pics once i get a hold of a set..
  • DrWhizBang
  • DrWhizBang's Avatar
08 Oct 2007 09:51
#175204
Wouldn't that solve the sidestand clearance issues that people seem to have installing rearsets?
KZ650C2 w/810CC in Saint John, NB
-- a sleeper, methinks.
