1/4 mile times
- Lorcan
- Speed Loony
Re: 1/4 mile times
05 Oct 2007 13:28
mike(nj) wrote:
That's good going Mike, well done
I did 11.53 on a stock wheelbase '79 ltd 1000. Had a 1105 kit, 29's, dyna S & coils. That was my 2nd time at the track ever.
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
- stever
Re: 1/4 mile times
06 Oct 2007 11:48
Very interested in this, I have a z1a with z1000 barrels and pistons , v and h pipe, K and n filters and dyna ignition and coils . This winter thinking of going the 1075 wisco and 29 mm smoothbore route so same spec as you guys above . Heres the question what will a 1075 with 29mms etc make at the back wheel on the dyno?:evil:
Would I be better with 1075 Wisco pistons or for a few dollers more
Ape sell a kit with 1075 pistons and cams? Jay I would really appreciate your input on this?
- StreetfighterKz
Re: 1/4 mile times
06 Oct 2007 17:51
Stever,
Get the cams. You'll thank yourself later on. You'll potentially lose some bottom-end torque but the mid-range and more likely top-end torque will be worth it.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1978 Z1R (roller)
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1978 Z1R (roller)
1979 z650 Resto-Mod
2018 Z900RS
- 77KZ650
Re: 1/4 mile times
06 Oct 2007 20:05
modprod wrote:
if you run under 10 seconds, dropping a tenth is huge!
you can say that again!A second is a "life time" in a dragrace
07 MDP Rookie of the Year
- stever
- themachine
Re: 1/4 mile times
08 Oct 2007 15:23
whadda ya think a 1170 will run with a set of 32-40 flat/round slides, a streetable cam, a ported head with big valves, a slick on an extended swingarm and weelie bars?
anyone?:huh:
anyone?:huh:
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
- tjettim
- themachine
Re: 1/4 mile times
11 Oct 2007 17:36
i wiegh about 150/160 so i could be considred light.
- davel
Re: 1/4 mile times
14 Oct 2007 17:01
Ran my 79 1000ST (Shaft) at the track last month and posted a best 12.2@113.5mph (80 degrees at sea level) My 60 foot time on that run was 2.15 sec...not good. Should be closer to 1.8 sec. Teminal speed suggests the bike will run somewhere in the mid 11's with a good launch. Bike has 1075, 34rs flat slides. Web Cam .365 lift, V&H megaphone.
Time slip says
60' - 2.154
330 - 5.302
1/8 - 7.920 93.32mph
1/4 - 12.205 113.47mph
Was my first time at the 1/4 mile track with a bike. Will try again before the season is out.
Time slip says
60' - 2.154
330 - 5.302
- madkaw1200
Re: 1/4 mile times
06 Nov 2007 15:53
i have two bikes one is a 79 kz 1000 with a 1075 kit web cams v&h pro pipe 29 smoothbores dyna s ignition and 4 over swing arm.im 6'2 250 lbs it runs 11.50s all day on pump gas. the other bike is a 1980 ltd 1000 with a 1105 kit v&h cams v&h pro pipe dyna coils and dyna s ignition 29 smoothbores and 6 over swing arm.it runs 10.30-40s both bikes on street tires.
- CoreyClough
- GPz550 Addiction
Re: 1/4 mile times
06 Nov 2007 19:42
So, anyone getting addicted to the 1/4 mile? :blink: I can't wait to take my 615 to the strip.
'85 GPz550(ZX550-A2)
- PLUMMEN
Re: 1/4 mile times
07 Nov 2007 14:39
fastestz1 wrote:
yeah,have you ever seen what it costs to make up that extra second?:Sricerocket wrote:1 second in the quarter equals out to a few lengths,and in the street forget about.<br><br>Post edited by: fastestz1, at: 2007/10/04 17:44Wow if you consider it these bikes are only 1 to 3 quarter of a second behind the modern fantastic plastics.
