Low cost Bike Lift ?
  • Nelson
  • Nelson's Avatar Topic Author
08 Sep 2007 19:44
#169472
I'm thinking of buying a lift. Any recommendations?
Harbor F has several models. This looks like the best one. I don't want something that will wobble and it's gotta be air powered.
www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=94813
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
  • btchalice
  • btchalice's Avatar
Re: Low cost Bike Lift ?
08 Sep 2007 21:42
#169501
www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=94121
i got this one and im really happy with it. its has air or foot lift
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
  • Nelson
08 Sep 2007 22:38
#169517
is it stable when fully lifted? somehow the design doesn't look stable compared to the standard scissor design.
are u using it with air or foot pumping?
thanks!
  • brich
  • brich's Avatar
09 Sep 2007 00:06
#169523
Me and my back :pinch: are very jealous of your bike lift. Im going to go take some advil and cry myself to sleep now. :P
1975 Z1 900, 1075 wiesco kit, web cams, smooth bores, dyna ignition, denco pipe, lester mags, wicked bad rotors, custom gauge face plates .. not much stock left.
  • Little B
  • Little B's Avatar
09 Sep 2007 01:30
#169527
Something else I noticed Harbor Freight selling are those electric and chain lifts that will lift up to 1 ton or so. Plenty of lifting power for most bikes I would imagine.
So, what if we took one of those things, mounted it to the roof of the garage and then rigged up a harness to attach to the bike's frame? Then, just push the up button and you could have it at any height you wanted...no back pain!
Now, you'd have to somehow stabilize the bike so that it didn't twist around while rising and being worked on. Seems like it would be fairly inexpensive and provide easier access for oil changes and such.
Has anyone done this already and if not, any thoughts as to whether it would work or not?
1981 KZ750-H2 LTD
  • bill_wilcox100
  • bill_wilcox100's Avatar
09 Sep 2007 06:13
#169542
Three thoughts on this:
1) The roofs in most structures are made to support specific loads over a wide area with no more margin than is required for there construction and in some places snow load. If you add 600 pounds at one point you may well have to reinforce the roof support or find a way to distribute it over 2, 3 or more joists to prevent sudden failure or to reinforce the existing structure of joists, rafters and purlins.
2) This brings me to the next issue which is failure mode... fail-to-safe or fail-to-unsafe. If the overhead support should fail (don't ask how I know) will it do a free drop to the floor or will it be cushioned by its rider? :pinch: You may need to consider some sort of frame that you role in under the hoisted bike for fail-to-safe support, to prevent free rotation and to hold the bike while you wrench around... gee sounds as if you're back to square one with a platform under the bike.
I use a lift similar to yours (cheapest I could get at Canadian Tire) and I had to make a fairly complex plywood adapter, using trial-and-error, that fit between the exhaust pipes. Essentially, the weight resets on the under side of the engine casing and is only mildly stable in the face of strenuous torqueing. Some, I hear, have made brackets to attach to the engine mounting bolts... but they will have to come forward with their inventions. :)
3) Remember, at the end of the day the objective is to have live, healthy and happy KZRiders ready for the road. :cheer:
Best of success!
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
  • GPz750KS
  • GPz750KS's Avatar
09 Sep 2007 06:41
#169548
I too have the Harbor Freight Lift, Nice item for the $$$. I trust it for all my bikes including my Guzzi and my Wes Cooley that is waiting for me right now...
Pic from earlier this year with the Kawasaki on it.
I prefer the hydralic foot pump. I live in a Condo and when the compressor comes on the neighbors complain. You ought to hear them bitch when I'm using my Harbor Freight Sandblaster....:P
Richard Z.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
09 Sep 2007 06:51
#169551
How about a build it yourself wood stand?
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
  • GPz750KS
  • GPz750KS's Avatar
09 Sep 2007 07:04
#169555
Now that is cool.... My problem is... If it's made of metal and plastic, I can do it.... If it's made of wood, well consider it firewood. I stink at building anything that is made from it.....
Richard Z.
  • btchalice
09 Sep 2007 18:55
#169666
I wouldnt climb on it at half lift but its pretty solid at full lift. plus the 4 wheels makes it real easy to move on concrete.
  • Little B
  • Little B's Avatar
09 Sep 2007 22:44
#169708
Thanks for your thoughts Bill!
Yeah, it would really bite to get crushed by my bike. I was thinking though that if the fail safe support was made in such a way that it allowed easier access to the underside of the bike, it may be a bit better than square one.
If anyone would like to share, I'm really interested in pictures of how folks got the brackets to attach to the engine mounting bolts. Since I already have the mini lift, it would be the least expensive option I'm sure.
1981 KZ750-H2 LTD
  • ronjones
  • ronjones's Avatar
10 Sep 2007 05:21
#169730
Well, for my bike teardown/rebuild I used a come-along, hooked into the supports for my garage doors. Once I had it up I lowered it onto a milk crate setting on top of a "car creeper". The car creeper/milk crate arangement allowed me to move the bike where ever I wanted it. I did end up putting too much strain on the garage door supports and bent one support and partially-pulled the bolts holding it up. When I need to use this method again, I will need to significantly heavy up that support area.
$10 comealong
$10 creeper
$00 milk crate
$2 for lag bolts to repair garage door supports
