Drag Racing Tips?
- Z1R rider
Re: Drag Racing Tips?
05 Jul 2007 17:01
kawtoy wrote:
depends on the track's timing system, on some .500 is perfect and on others .000 is what your looking for.
I always use a street tire at 30 psi,(running low pressure in a street tire deforms the footprint) and just spin it enough to clean the dust and pebbles off, not to heat it, then go right to stagin. I leave on the last yellow light on a .500 tree.
reaction times vary with coffee intake :laugh: 60's are 1.7s & 1.8s
Barber wrote:I hope you meant .510-.520 reaction times. .01 reaction time would mean you left about .49 seconds before you should have and you would have seen a nice bright RED light.My reaction time and my bikes reaction time would net me .01's, and .02 reaction times.. .
1978 KZ1000, Z1R
1999 250 Ninja race bike
2013 WR250F, fun in the dirt
- dnyce
06 Jul 2007 21:14
Barber wrote:
gd stuff mostly, i just wana say if you're gona be actually racing and not just fun runs, skip number 4. if your always staging 1st, your competitors will catch on and use that against u, by staging 1st and making u rush, therefore disrupting your routine and possibly causing a bad reaction- you should be ready when u lite up the second set of bulbs whether or not you went in before the other guy or not.
the one finger clutch thing is a new one for me...but if it works, go 4 it. i use all 4 fingers-ultimate control.
#7 is the main one, never forget it!
To be good at the lights, you have to learn "your" bike.. i.e. it's reaction time, what it's going to do, ect...
My advice would be...
1.. good burn out, no dry hops afterwards.. pull straight to the line and stage..
2.. use the front brake to stop, not to stay there... that's what your feet are for...
3.. ONLY use ONE finger on the clutch lever... reason being is that it is damn near impossible to "pop" it that way.. and you don't want to pop it, you want to slide it off the line... put down as much power as you can without spinning....
4.. stage before the other guy does... this gives you a few more seconds to get ready.. i.e. get your body positioned, get your RPM's up, and get focused on the lights....
5.. watch the lights and the light's only... Back when I dragraced every weekend, I would leave when the last yellow light was on at it's very brightest.. My reaction time and my bikes reaction time would net me .01's, and .02 reaction times..
6.. Keep as much body weight as far forward as possible..... It's hard to win races when your looking at the sky..
7.. Have fun...
- Barber
07 Jul 2007 05:42
kawtoy wrote:
The track I raced at a .000 was perfect... I guess I should have clarified this in my post..
Green 76 Z900 A4
- Barber
07 Jul 2007 05:49
dnyce wrote:
The only reason I told him to stage first is that he's learning, and it gives him a little more time to get ready...
The one finger launch works great... been using it for years... but you do have to have a strong finger..
And yes.. #7 is the most important of them all...
Post edited by: Barber, at: 2007/07/07 08:52
Green 76 Z900 A4
- dnyce
07 Jul 2007 17:18
is your lever cut down too? im guessin you use your middle finger rite? i tryed the two finger technique, but after awhile it was workin my fingers to much, (heavy springs-cramped up in the finals, redlite)
ill giveit a shot anyway
Post edited by: dnyce, at: 2007/07/07 20:20
- Barber
07 Jul 2007 21:56
I use my trigger finger... But I run a Easy-Pull Clutch System on my bike as well... That way no matter how stiff your springs are, you can still use one finger....
Get you one of these and try it...
www.motorcycle-superstore.com/item.aspx?...tment=656&Division=6
Green 76 Z900 A4
- kawtoy
08 Jul 2007 08:40
Where does that mount at? Do you have to get shorter cables? How much difference does it really make?
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
- Barber
08 Jul 2007 10:28
Right up beside the clutch lever... your clutch cable goes in one side, and a really short cable goes in the other.... and It's only about 3/4 inches wide, so it really doesn't take up much room...
It makes quite a bit of difference... there are two different settings(holes) and I have mine set up on the easiest.... basicly it's a fulcrum point with various holes in the lever to attach the cables...
They were designed for dirtbikes, which is the way I was introduced to them...
Green 76 Z900 A4
- dnyce
09 Jul 2007 17:26
oh, thats how u do it with one finger...i rode a bike with the ez pull, didnt like it. seemed like it lost the true clutch feeling, to me anyway.
- Barber
09 Jul 2007 20:06
I did it without the easy pull on it too, but like you said after a few rounds your finger gets a little tired.... thats the reason I went with the easy pull system...
And yes it does take a little getting use to... but after you run it awhile you get use to it and can feel it just like a regular clutch set up.....
Green 76 Z900 A4
- dnyce
10 Jul 2007 22:27
assuming they're pretty reasonably priced, id actually try one out based on what u said-but im eventually gonna get a lock-up clutch so it would be kinda pointless in my case.
