Rear tire problem
  • StreetfighterKz
  • StreetfighterKz's Avatar Topic Author
Rear tire problem
21 Jun 2007 16:49
#151574
Hey,
Well I was riding my Duc home yesterday and the back end seemed a little "off". So when I got home a checked the rear tire and found whats in the pics. I don't ever remember seeing the gash before. I'm not sure if it was there and I never noticed or if I hit something (although I would think the gash would go with the tire tread not against it) or somebody took a knife to it.
What do you guys think? I normally run 36psi and it showed 34psi yesterday when I checked it and it was 30psi today. I bought the tire last June/July and just had it installed on May 31st. It was installed at the cycle shop I used to work at by a guy I know with me watching so I'm sure it didn't happen then. The sad thing is that the tire has about 300 miles on it and the D208 has been discontinued for about 2 years so a exact replacement is out.
What's your opinion? Should I ride on it or buy a new tire ?
Later, Doug
Post edited by: StreetfighterKz, at: 2007/06/21 19:50
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • StreetfighterKz
Re: Rear tire problem
21 Jun 2007 16:51
#151577
Another view
1979 z650 Resto-Mod
2018 Z900RS
  • z1rick
  • z1rick's Avatar
21 Jun 2007 17:06
#151585
Looks like you may have ran over something with a sharp edge, on the road. Maybe something metal.
Anaheim CA
1999 KZ 100P
1974 Z1 900 Project
1977 (2) KZ 650 projects
  • PLUMMEN
  • PLUMMEN's Avatar
21 Jun 2007 17:25
#151600
it dont look that bad,but if its leaking probably better change it;)
  • kawtoy
  • kawtoy's Avatar
21 Jun 2007 17:45
#151604
Looks like the tread is pretty dead there so it would have to be a deep hole to go all the way through. But it is leaking so something is going on. Might be a pin hole or something. You could always smoke the tire a bit and see it the mark goes away :side: . That is a tough choice. The right thing to do is change it for the sake of your skin. Since you felt it while riding that tells me the tire has been damaged to a point where it is affecting the performance.
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
  • KZQ
  • KZQ's Avatar
  • Away
  • Administrator
  • Administrator
21 Jun 2007 17:50
#151605
If it's loosing pressure try spraying some soapy water toward the stem area. Is the stem leaking? If not replace the tire.
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • z1rick
  • z1rick's Avatar
21 Jun 2007 20:18
#151644
Check the rim for damage also, a bent rim could leak around the bead.
Anaheim CA
1999 KZ 100P
1974 Z1 900 Project
  • BSKZ650
  • BSKZ650's Avatar
22 Jun 2007 05:14
#151707
does look like you ran over something, the soap and water deal is the best way to find a leak, bottom line its your butt on the bike and how do you feel about loosing a tire while riding
77 ltd1000, current rider
76 kz900, just waiting
