Just got 77 KZ650 and It Runs
  • srobie1
  • Topic Author
18 Jun 2007 18:14 #150707 by srobie1
Just got 77 KZ650 and It Runs was created by srobie1
I bought the bike in hopes to have a good daily driver. Its A 77 kz 650. The guy I bought it from said he had bought it over 2 years ago and has done nothing with it. He also said it sat for 5 years prior to him getting it. So its a barn find. I dumped a little marvel mystry oil on the pistons, new plugs, oil change and filter, a little carb clearner, and a battery. And the damn thing started right up. Ran great idled was high though (4K rpm).It has no air box so I thought this was the reason, so I adjust carbs down. Then I heard a rapping/slapping/ping. I thought maybe Bearings or rings. I have checked the plugs number 3 is fowled and so is number 2 (not as bad as 3)number 1 and 4 are clean as can be. I know the carbs are not right and need to be cleaned completly. Am I looking at carb ping noise or do I need to do a ring job or worse? The bike only has 24k on it and needs the normal work from setting for so long, tires brakes etc.. I dont have a ton of money to dump into it. I am a machinist by trade and am good with a wrench. This is my 1st street bike. I looking for some solid advise on which way to tackle this one. Is it possible to take the top end off while the motor is still in the frame? Or is this just a possible carb job like I am hoping?
Post edited by: srobie1, at: 2007/06/18 21:49
  • The Gringo
  • ¡Usted no necesita otra motocicleta!
18 Jun 2007 18:40 #150720 by The Gringo
Replied by The Gringo on topic Just got 77 KZ650 and It Runs
First of all welcome to the board. Sounds like a nice find. These old 650's are pretty tough and yours does not have very many miles so chances are good that your problems are minor in nature. Cylinders 2 and 3 are both fired by the same coil and set of points assuming the bike still has points. Your ignition system could be part of your problem. You also could be getting noise from an out of adjustment cam chain. It sounds like you went about firing it up in the right way. It would be wise of you to try and get your hands on some sort of service manual the factory ones are best but clymers are helpful as well. Also put your location in your signature there might be someone from here close to you willing to lend a hand. Also which 650 do you have the B model (spoke wheels) or the C model (mag wheels)? Oh and everyone here loves to see pics.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
  • srobie1
  • Topic Author
18 Jun 2007 18:56 #150728 by srobie1
Replied by srobie1 on topic Just got 77 KZ650 and It Runs
Thanks,
I am located in Clearwater, Florida. And I do have a clymer manual. The bike has Mags, not spokes. I have been trying to post pic of the bike but wont go thru for some reason. I will keep trying maybe have one on soon. Any help is greatly appreciated.
Thanks
  • srobie1
  • Topic Author
18 Jun 2007 18:58 #150729 by srobie1
I am located in Cleawater, Florida. I do have a manual (clymer) the guy i bought the bike from gave it to me. The bike has mag rims. Any help is greatly appreciated.
  • The Gringo
18 Jun 2007 19:19 #150734 by The Gringo
Ah Clearwater or as I always liked to call it "God's waiting room" :whistle: As to your picture problem try resizing them to no more than 550 pixels wide and they should load.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
18 Jun 2007 21:27 #150772 by Mark Wing
Replied by Mark Wing on topic Just got 77 KZ650 and It Runs
Welcome to the site. Check the coil connections too and yes you can pull the top end with the motor in the frame.
Mark
Yorba Linda Cal.
19 Jun 2007 04:42 #150807 by BSKZ650
Replied by BSKZ650 on topic Just got 77 KZ650 and It Runs
welcome, you might want to give it a full tune up, new plugs points condenser, if it still has them, pull the valve cover and check the valves and adj the timing chain, set the timing , and run a compression check, after you make sure all is well then clean the carbs, with that low of miles, it should run for a long time once its back right
77 ltd1000, current rider
76 kz900, just waiting
  • srobie1
  • Topic Author
19 Jun 2007 13:32 #150916 by srobie1
I was planning on doing a compression check, I am waiting on a friend to borrow his compression tester. I have changed the plugs. I will try a new condenser. It seems to be getting good spark though. I am more conserned with noise at low RPM's. Checking the ignition timing is something will have to do for sure. Thanks for the tips and all the welcomes Guys this a great forum!! Please keep them coming. I am statring to have hope that I won't have to rip the top end apart. And any help is greatly appreciated.
Thanks
