Thinking of buying '77 KZ-650
  • MrDonut
  • MrDonut's Avatar Topic Author
18 Jun 2007 12:25
#150615
Hello,
I'm thinking of buying a '77 kz 650, I know nothing about bikes but I'm pretty good with tools. Are there any typical problems with these that I should look for or know about in advance. I used to fix 70's ski-doos and they had reoccuring carb problems, any nagging problems in the engine/carbs?
Thanks, JimmyD
1977 KZ650 c1
  • N0NB
  • N0NB's Avatar
  • Blue handles better
Re: Thinking of buying '77 KZ-650
18 Jun 2007 13:51
#150631
Most issues are related to neglect and improper maintenance. For a 30 year old machine with good care you can expect normal wear items like tires and drive chain and sprockets to need replacement. The stock ignition coils don't have the greatest reputation so many of us install aftermarket coils from Dynatek or ACCEL. A Dyna S-2 electronic ignition is also a popular upgrade.
One subtle item is the steering head bearing set. They are loose bals on a flat race and will develop a wear spot over time that will act as a detent and affect steering. Replacement tapered bearing kits are readily available.
I worked on a '78 SR 650 that had the swing arm bearings and sleeve worn out most likely due to lack of greasing. Again, maintenance is important to the condition of any bike.
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel :D )
  • kawsakiman
  • kawsakiman's Avatar
18 Jun 2007 14:46
#150648
and a good idea is to get a manual and read it.
valve lash is almost always a problum with older bikes since there is no one is really sure when the last time it was done.
but hey!
welcome to the sight !
if you get it please post some pictures.
hope you got thick skin :laugh: :woohoo: :lol: :P :sick:
Post edited by: kawsakiman, at: 2007/06/18 17:47
