New owner
- Makarth
New owner
17 Jun 2007 11:58
As of yesterday i am now a proud owner of a 78 Kz1000. Sadly im still many miles from it. Meh but who cares it's still cool that i have one and im excited to get my ride on. As a small side note, is there some sort of compression release vavle for the engine when you try to turn the bike over? my dad started the bike to drive it up our 45degree drive-way and when he turned the key to the on position it hissed at him and scared the crap out of him. It was pretty funny to hear that over the phone.
- kawtoy
Re: New owner
17 Jun 2007 13:17
No compression release. If it hissed at him then it will be somethng you pat attention to. It should not be doing that. Most likely have a loose spark plug or something. If it truely did it when the ignition was turned on then who knows what it could be.
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
- godsjester71
Re: New owner
17 Jun 2007 16:05
MAKE SURE THERE ISNT A CAT UNDER THE HOOD!!!! :woohoo: :woohoo: :woohoo:
- Makarth
Re: New owner
17 Jun 2007 21:02
it wasn't running so i dont think it was a spark plug leak... he said he turned the key to the on. he didnt try to turn it over or anything.
and with my luck it is a cat lol.
- z1rick
Re: New owner
17 Jun 2007 21:12
Sounds like some kind of electrical short that was arching. Look over the wiring for bare wires, check the battery for corrosion and loose cables, things like that.
Anaheim CA
1999 KZ 100P
1974 Z1 900 Project
1977 (2) KZ 650 projects
1999 KZ 100P
1974 Z1 900 Project
- Vter Bob
Re: New owner
18 Jun 2007 17:41
Check the coils for cracks....
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
1981 KZ550 LTD
1982 KZ1000 LTD
- The Milkman
Re: New owner
18 Jun 2007 18:09
If it had been run recently, it may have been the ignition making spark at on of the plugs and firing that cylinder a bit. My bike does that occasionally.
Enjoy the bike when you get it and
Ride safe
Ride safe
- cafekz750
Re: New owner
19 Jun 2007 11:32
Does it happen every time the key is turned?
Could be as simple as a hot gas tank in the sun, put key in the ignition and swing the bike up vertical and have the gas cap vent hiss from the release of pressure.
Maybe not.
I hope it's not serious.
Maybe not.
1981 KZ750H2 - V&H 4-1 pipe, pods, jetted, clubmans, homebrew rearsets, 18" rear wheel and more.
Parting out a 1982 KZ750H3 to fund future projects
2 other non-Kawasaki motorcycles
- kzwolfsr
Re: New owner
19 Jun 2007 11:53
I think Cafe is on to something. My bikes hiss at me from the tank cover all the time in the sun. I had to open my 650 cover yesterday to stop that noise, it was annoying!
Original man of the Caribbean
- Makarth
Re: New owner
19 Jun 2007 17:00
i'll have to check it when i get home but my dad says it only happens after it has been running and he says it sounds like the pressure release on the semi-truck breaks.:whistle:
