ZX550A1 - Godsjester71
- godsjester71
16 Oct 2006 21:52
Two winter projects are slated:
Engine
Front end
Various small things
If time allows:
Rear swing arm
Front braided lines (if progressive springs)
Engine:
Valve adjust
Replace gaskets and rings
Check timing chain, chain tensioner
Front end:
Rebuild forks
Progressive springs/cut out antidive (maybe to be discussed)
Taper roller bearings for the heads
Various small things:
Chain and sprockets
Carbs
Rear tire and bearings
replace broken/missing bits
Marker lights
Repair fairing
If rear tire and bearings don't fix the wobble then.
Rear Swing arm:
New upgraded bearings and bushings
Replace shock (ouch, rebuildable?)
Part I allready have:
Gasket kit
80% of fork parts
Center stand (hope it clears muffler)
So this is my first project, do you think this is too much for a winter? That is roughly the order I would do it in. I can put in a day a week I bet. Another $600 in parts and tools (my set is fair)? Shock we are looking at another $400?
I also know that "While you're in there"s can make a job overwhelming, but its good to know and invite them
BEFORE:
Post edited by: godsjester71, at: 2006/10/17 00:56
Engine
Front end
If time allows:
Rear swing arm
Engine:
Valve adjust
Front end:
Rebuild forks
Chain and sprockets
Carbs
Marker lights
Repair fairing
Rear Swing arm:
Gasket kit
80% of fork parts
BEFORE:
- neilage66
Re: ZX550A1 - Godsjester71
17 Oct 2006 05:42
You certainly are one ambitious mutha...more power to you!
:lol:
- loudhvx
17 Oct 2006 09:18
Man, that back tire was worn out in the last century! Definitely time for a new one! And while you're in there, replace the valve-stem caps
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- godsjester71
17 Oct 2006 10:17
Do you think I am biting off more than I can chew in a winter?
Engine has to be done, it's leaking too much over 4k and I worry about the back end of that leak not getting enough life blood. I've also heard valve seats are something to be looked at.
A close second is rear tire. Valve stem to be added in. This is no biggie.
I'd like a well sorted out bike for once, and this is the one. I know a better beginning subject would be easier, but this is what I've got.
:whistle:
I will be using this thread to sort my project out, blue is the color of things directly related to the project, red for communications, black for discussions. I will be cutting and pasting from other threads/forums to keep it all in one place.
Post edited by: godsjester71, at: 2006/10/17 13:19
- loudhvx
17 Oct 2006 11:18
Cool! At least it's a sunny day in your bike photo! ...Forgot what one looks like.
1981 KZ550 D1 gpz.
Other links.
Other links.
- godsjester71
Re: Engine Rebuild Tips
23 Oct 2006 11:47From CoreyClough on GPz550:
"Base gasket is a must. I'd go with at least new rings....no wait... do a compression test(warm, and throttle wide open), and see how it is. I have 44000 miles on mine, and rod knock happened bfore the compression got below 135(that was the psi of all of my cylinders). 180psi is new, and 109psi is rebuild time. If it's low, then hone the cylinders, install new rings, and ride it for as long as you want. Only go the 615cc route if you're really serious about keeping the bike, and then do whatever else you can think of while you're in there, including rebuilding the head, cam chain, and a lot of these ->..."
- godsjester71
Re: Front End Tips
23 Oct 2006 12:12Please Log in or Create an account to join the conversation.
- godsjester71
Re: Engine Compression
30 Oct 2006 07:30
Lou came by with the gauge and all looks excellent! Thanks Lou!
1 186
2 188
3 186
4 187
Yay! The rings stay!
Post edited by: godsjester71, at: 2006/10/30 10:32
1 186
2 188
3 186
4 187
- godsjester71
- loudhvx
Re: Headers
15 Nov 2006 09:47
www.theopenpress.com/index.php?a=press&id=6535
made it into a link
Looks good, but you have to work fast and not go over previously painted areas. Let me know if you try it.
Post edited by: loudhvx, at: 2006/11/15 12:51
made it into a link
1981 KZ550 D1 gpz.
Other links.
Other links.
- Nevco48
15 Nov 2006 13:36
godsjester71 wrote:
Damn, color coded threads! What color did you pick out for the photochopping crew when they start hijacking this thread?
- godsjester71
15 Nov 2006 13:57
Nevco48 wrote:
Well, I'm hoping that wont happen outside the chit chat area, if not, maybe some hopes for some rights on this thread alone. But I'm also hoping for some security thru obscurity. shhhh...
godsjester71 wrote:Damn, color coded threads! What color did you pick out for the photochopping crew when they start hijacking this thread?
