1980 KZ 550 LTD project
- mtfr56
18 Nov 2026 07:26
My good friend who I used to work with on my Honda racecars (I built, he drove, 4 championships) is a plumber and found a 1980 KZ 550 LTD behind a customer's house, covered by what used to be a tarp. About the only thing it had going for it was the engine turned over and it has new tires. He brought it over to my house and we got it running. Our idea is to make a cafe style bike out of it. So far, I have put drag bars on it and have a new seat coming.
One of the things that we're going to do is replace the air box with pods. I am sure others have done the same. My question is what to do with the air injection system. My thinking is put a filter at the end of the hose.
I find this somewhat humorous. Both my 73 MG Midget and Toyota had air pumps, a rather silly idea where air is pumped into the exhaust to dilute the emissions. This seems to be along the same line. Has anyone just removed the whole thing and plug up the holes at the top of the heads?
This is a long term project. So far, I have cleaned up most of the frame and am working on the headlight (rust) bucket. We need to figure out the front turn signals as with the shorter bars, the LTD signals will not mount on the bars. My thinking is to get replacement stems and put them on the headlight.
This is the first time I have worked on a non-Honda in almost 50 years. All Hondas use the same engineering, whether it was a 350 twin racer, my CRX racecars or my s2000. It's interesting to see the difference. I am in uncharted territory. I welcome any advice that anyone has to offer.
Thank you,
Mat
Thank you,
Mat
Re: 1980 KZ 550 LTD project
19 Nov 2026 01:03
Welcome from the UK, if you use the search function there are several threads here regarding "air bleed" system removal. It is straight forward
- bound
- If you ain't HURTIN' you ain't LEARNIN'!!
19 Nov 2026 07:34
Welcome, I am very curious to see what you make happen to this bike!
1982 KZ1000M2 CSR
1983 KZ440D5 LTD
1985 GPz 550A2
Craig
1983 KZ440D5 LTD
1985 GPz 550A2
Craig
- Kelly E
19 Nov 2026 09:04
I moved the front turn signals to the headlight mount on my 77' KZ 1000 LTD using a set of aftermarket mounting stems.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
1983 Honda CB 1100F
And more
