1980 KZ750 Restomod
  • HulkSmash
  • HulkSmash's Avatar Topic Author
1980 KZ750 Restomod
09 Nov 2025 04:49
#918879
I'm in the process of building a KZ 750 and have access to a 1985 GPZ750. Now, I know the frames are different but how many parts are interchangeable for my 1980? I am thinking engine swap for sure but are the brakes and wheels swappable? Has anyone used a 85 gpz as a parts bike on the E model? Just looking for some input before I pull the trigger on the buy. Cheers.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: 1980 KZ750 Restomod
09 Nov 2025 05:48
#918883
Definitely the motor, carbs oil cooler and ignition system. I would use the instruments too :)
The following user(s) said Thank You: HulkSmash
  • scubaanders
  • scubaanders's Avatar
09 Nov 2025 21:36
#918926
Unfortunately the rear motor mounts are different between the KZ750E and the ZX750A (Gpz750-83-85) engine cases. The ZX engine case can be put in your 750E frame if you craft some spacers and front mounts.
wheels will pretty much swap right over.
Brgds Anders
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
