KZ440 LTD Build
- drdominodog51
KZ440 LTD Build
30 Apr 2025 21:02 - 30 Apr 2025 21:11
Hello all,
I got my KZ440 LTD back from my mechanic today and it’s running now without dumping gas everywhere (which is an improvement). I thought I’d start this thread to document my work on the bike as time go on. My goal is mostly to get the bike running well and meeting legal requirements so I can take my motorcycle endorsement skills test on it.
My first order of business is to fix the idle as it’s borderline unridable right now. I thought rebuilding the carbs would address this, but the bike appears to have a higher and higher idle as it heats up (to ~4000 rpm). Now, I’ve read some topics on this, so tomorrow I’ll pick up some carb cleaner to check for vacuum leaks and play with the throttle cable adjustment if that does nothing. I suppose checking the timing advance and valve clearance will come after that (although I need to do both of the latter even if I didn’t have this issue).
I’m operating under the assumption this is a vacuum leak as that would explain the rough cold starts as well (it sounds like one cylinder wants to die).
Despite this, I rode the bike around for an hour or so and had a blast. I definitely need to work on my overall stability riding, but this was my first time riding anywhere on public roads so I thought I didn’t do half bad. A friend said I looked like I was wobbling going straight on the road, and I definitely chose some questionable times to be doing things (like shifting in the middle of a turn or using a front brake to slow down when I realized I needed to sharpen up my course mid-turn). I’m sure this’ll come with time and getting more comfortable on a motorcycle.
As a second issue, I installed the horn today and it doesn’t work. I didn’t spend much time diagnosing it because I just wanted to ride around. I’m assuming the lack of a ground for the horn is the issue. I’ll order one and see if that fixes it.
Cheers.
Cheers.
'80 KZ440A LTD
Last edit: 30 Apr 2025 21:11 by drdominodog51.
Re: KZ440 LTD Build
01 May 2025 01:02
didn't you start by saying you "got the bike back from my mechanic" so what did you pay him for if it isn't running right ??
Re: KZ440 LTD Build
01 May 2025 06:11
Good luck with your project.
This may help... www.kzrider.com/forum/faq-wiki/618026-new-owner-things-to-know
The following user(s) said Thank You: drdominodog51
- drdominodog51
Re: KZ440 LTD Build
01 May 2025 07:36 - 01 May 2025 07:42That would be it. I didn't realize the aerosol test wasn't conclusive, but that makes enough sense. The boots appear to be in pretty good shape externally but maybe they just got wiped down. I'll still poke around and look for anything obvious besides the boots.Good luck with your project.
As for the mechanic, I can't blame him for not noticing this considering he only really took the bike around the block. It took around 10-15 min for the bike to get hot enough for this to be a problem.
'80 KZ440A LTD
Last edit: 01 May 2025 07:42 by drdominodog51.
- drdominodog51
Re: KZ440 LTD Build
02 May 2025 07:40 - 02 May 2025 07:48
Using carb cleaner for diagnostics didn’t have a noticeable effect, so I pulled the carbs out last night and looked around.
(Edit: The crack is just behind the screw on the close carb holder. The far mating surface doesn’t look good either; does it?)
One of the carb boots has a tear in it. I’m not sure if the tear was caused by me removing the carbs, but either way I’m replacing both carb boots. I already put penetrating oil on the screws and am going to keep doing so for a couple days to get them out.
The second thing I noticed is that the petcock vacuum line was sealed with what appears to be a little clump of foil shoved into it. This bike has a Yamaha Raptor petcock clone on it already so I don’t need the line. I’ll order the matching plug (11012-1129 or 11065-0282) from the other carb and install that instead of the poorly plugged line.
As for reinstallation of the carbs, I’m probably going to pull the battery case from the bike to get a little more room to push the airbox away from the carbs and reinstall it that way with some engine oil on the carb boots. I’ll be keeping the same airbox boots, but only because the part is on backorder.
Thanks for the help all.
'80 KZ440A LTD
Last edit: 02 May 2025 07:48 by drdominodog51.
Re: KZ440 LTD Build
02 May 2025 07:52
Looks like you are on the right track, the discolouration around the joint between the boots and head suggests leaking
The following user(s) said Thank You: Gdizard, drdominodog51
- drdominodog51
Re: KZ440 LTD Build
19 May 2025 08:13 - 19 May 2025 09:08
It's been a minute since I've posted an update here for reasons below.
It took a propane torch and chisel to get the carb boot screws off, but I did get them off and replaced the carb boots with a little Permatex anaerobic added to make sure the new ones would seal. After reassembling the bike and a little bit of cranking from the starter, the bike lost all electrics. I started by testing all fuses and the battery with the multimeter. The battery and all fuses tested fine with my multimeter, but the main fuse appeared green for whatever reason. I ended up replacing the main fuse and the battery, and the electrical systems came back to life.
My issue now was getting fuel to actually flow from the gas tank to the carbs. I don't know why this was so difficult, but it took a lot of screwing around and tilting the bike to get it flowing. After some idle screw fiddling, the bike now runs good enough!.
The idle is probably set too high as it gets as high as 2100 rpm after 1.5h of driving, but this isn't really a problem for me driving around town and seems to help a little with coldstarts. Also, the throttle hangs on shifts and revs in neutral, but it's not unbearable.
With the bike as it is now, I've been riding around at least an hour every day and even started riding to work as of today for my commute though I'm deliberately offsetting my work hours to avoid rush hours because I'm not there as a rider yet.
The only real issue I have with the bike currently is that the finding first from neutral is weirdly difficult as of yesterday. It's not a problem from second through, so it's not really a major issue for riding either. I may look into that, but I'm happy where the bike is and am enjoying learning how to ride.
'80 KZ440A LTD
Last edit: 19 May 2025 09:08 by drdominodog51.
Re: KZ440 LTD Build
19 May 2025 08:39
If you are having a problem with 1st when stationary I would suggest checking clutch adjustment against the FSM (selecting the rest when moving are less clutch dependent)
- drdominodog51
Re: KZ440 LTD Build
29 May 2025 15:20 - 29 May 2025 15:21
My week of enjoying the running bike was nice, but I would have liked it to be longer than a week.
I took a look at the clutch cable and realized it been rubbing on the headers. It's all worn through/melted, so that's going to have to get replaced. Whatever; that's not an immediate issue as the clutch does mostly work.
As of Tuesday, the bike now stalls after getting hot and is almost impossible to restart until it cools back down. It will sometimes fire back up for a bit with the choke fully on but dies coming to a stop with the clutch engaged. After it dies again, it may fire once or twice when cranking but won't ever restart until its cool.
I understand this can be a number of things, but I'm hoping it's just a combination of the increased ambient temps, a high spot in my fuel line, and the relatively restrictive fuel filter. I still need to do diagnostics and verify it is not a spark issue. If it is a spark issue, it'd be a bit weird as this should have points instead of a pick-up coil which I know sometimes die like this.
Here's to hoping the bike stays running longer after this set of repairs.
'80 KZ440A LTD
Last edit: 29 May 2025 15:21 by drdominodog51.
- Nerdy
Re: KZ440 LTD Build
29 May 2025 17:45
Keep in mind that ignition coils can die that way as well.
Recommend you carry a spare spark plug or two with you. When the bike dies, pull the plug cap(s), insert one or both plugs from your pocket, and test for spark without burning your fingers.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
The following user(s) said Thank You: Wookie58, drdominodog51
- Michi
Re: KZ440 LTD Build
30 May 2025 05:55As of Tuesday, the bike now stalls after getting hot and is almost impossible to restart until it cools back down. It will sometimes fire back up for a bit with the choke fully on but dies coming to a stop with the clutch engaged. After it dies again, it may fire once or twice when cranking but won't ever restart until its cool
These bikes can be a real pig for some reason, much unlike the 4-cylinder Kawasakis (at least, from my experience, those once set just work).
What you've got is a permanent project bike (like mine). Currently, mine has the same issue and it's taken me 2 days to nail it down. It has had the same symptoms before, for several (different) reasons. We've got to remember, we're riding very old bikes with very old wiring and tanks. When everything is going great, you still can't trust it.
It's unlikely to have overheated - the engine is a robust unit and unless you're running low on oil and in a very hot climate that probably hasn't happened. Look first to your electrics and charging system. Is your charging system charging? What's your battery voltage right now, and are you seeing the expected 13+ volts across the battery terminals over 4000 rpm? If not, check your stator has continuity across its output wires (yellow) and the right resistance (about 0.5 ohms to 1.5 ohms). If your stator is fried, then investigate. Leave it overnight and see if your battery is in good enough condition to hold a charge. Then come back and check the diodes aren't open circuit or leaking both ways on your reg-rec unit.
If all this checks out, then move on to investigate whether it's a fuelling problem.
KZ440A LTD (1980)
- drdominodog51
Re: KZ440 LTD Build
06 Jun 2025 19:10
I finally rode the 440 enough for it to get hot and die again. This time I was close enough to walk it home and pull the spark plugs. I was getting incredibly weak or no spark when cranking.
Also, the ignition coil looks to be in pretty rough shape from what I can see without pulling the gas tank, so I’m going to jump on limb here and blame that. As it looks like replacement (non-oem) coils are cheap enough, I’m not going to bother with more diagnostics until that’s gone.
On that note do y’all have any recommendations on what ignition coil(s) to get? I know I need something that’s 4 Ohms for the points but that’s about it.
'80 KZ440A LTD
