- Thank you received: 732
73 Z1 mutt/mixed breed Build
- slmjim+Z1BEBE
PN# 13116-021... Quick question, does anybody know the length of the clutch push rod? ...
29 cm / 290 mm
EDIT: Corrected cm (no decimal point) per hardrockminer.'s catch. 29cm is correct.
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
- Thank you received: 1088
I think that should be 29 cm Jim.
2.9 cm / 290 mm
Good Ridin'
slmjim & Z1BEBE
- slmjim+Z1BEBE
Yup. Oops... Thanks for the catch.
2.9 cm / 290 mm
Good Ridin'
slmjim & Z1BEBE
Edited to correct.
Good Ridin'
slmjim & Z1BEBE
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
- Coyote
- Thank you received: 22
77 KZ 1000 A
21 Z900 RS
Project 73 Z1
- Coyote
77 KZ 1000 A
21 Z900 RS
Project 73 Z1
- Coyote
77 KZ 1000 A
21 Z900 RS
Project 73 Z1
- Coyote
77 KZ 1000 A
21 Z900 RS
Project 73 Z1
- Coyote
77 KZ 1000 A
21 Z900 RS
Project 73 Z1
- slmjim+Z1BEBE
Does anybody know an easy way to get the foot peg studs out? I need to rob one from the 76 fraime I've got to put in the 73.
Remove the nut behind it. Should unscrew with a pipe wrench or curved jaw channelocks.
Good Ridin'
slmjim &Z1BEBE
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
- Coyote
This one came easily thank goodness. Thank you very much
77 KZ 1000 A
21 Z900 RS
Project 73 Z1
- Coyote
77 KZ 1000 A
21 Z900 RS
Project 73 Z1
