Project KZ440 Scrambler
- Adrian719
Re: Project KZ440 Scrambler
06 May 2024 13:53I swear my wheels say tubeless on them. Most likely though I will just throw heavy duty tubes in anyways.What did you paint the forks with?
I used Duplicolor Hi-Build fleet coating primer , and then Duplicolor Acrylic Enamel . Although it might be better to go with this for the color coat.
- !Seymore
- Ride on...
06 May 2024 17:01 - 06 May 2024 17:02Can you share a PIC? Not that I don't believe you, but the proof is in, well... I know my 79' SR rims are not tubeless, although I did run my rear without a tube for a bit. I remember there were discussions @ KZ Info about this, along with the pros/cons and there was a cut-off date. Sorry, don't remember the date...swear my wheels say tubeless on them. Most likely though I will just throw heavy duty tubes in anyways.
C.
79' KZ650-D2 [fsm] (Max)
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
Last edit: 06 May 2024 17:02 by !Seymore.
- Michi
06 May 2024 17:22 - 06 May 2024 17:23
My 440 runs tubes. Front is from a 400 (watch out for the different brake rotor offset) and definitely doesn't say tubeless, so it's got a tube. But I had no doubt the rear takes a tube. From what you're saying, I should check my rear wheel. Fairly sure it doesn't say tubeless, but it was a long time ago when I looked. The aperture for the tyre valve on both wheels is smaller than for tubeless valves. I think it requires tubes on both front and rear mate. Check it to be doubly sure.
KZ440A LTD (1980)
Last edit: 06 May 2024 17:23 by Michi.
- Adrian719
07 May 2024 18:02
I have no idea where I got the idea they wheels said tubeless, took a closer look today and nothing.
Dealing with a broken off tap in the god damn exhaust stud hole right now. Tomorrow i'm going to get a large o-ring to cut into a plug for the carbs as I lost the originals.
Also trying to find some foot pegs that I like that will fit this bike as the stock ones were too bulky and ugly.
The following user(s) said Thank You: !Seymore
- !Seymore
- Ride on...
07 May 2024 19:22 - 07 May 2024 19:24
C.
Last edit: 07 May 2024 19:24 by !Seymore.
- sf4t7
07 May 2024 19:52
Tubeless rims also have small ribs around the inside to help retain the tire beads.
Scotty
1974 Z1A
Yoshimura 987
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
Yoshimura 987
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
The following user(s) said Thank You: Scirocco
- BruceinOH
08 May 2024 04:38
The following user(s) said Thank You: Adrian719
- Adrian719
- ckahleer
09 May 2024 09:41
If these carbs a like my KZ305 carbs, be carfull not to push the plugs in so far that it blocks the fuel passage from the main jet. Also, they should extend long enough so they are held in place by a tab in the bottom of the float bowl.
I had to faburcate those plugs when I first got this bike, but your solution looks much simpler.
1997 ZL600
94 KE100
82 KZ305
85 VF1100c
94 KE100
82 KZ305
85 VF1100c
- Adrian719
09 May 2024 18:07
Alright so I bought a rubber gasket for some agricultural equipment and cut it into little plugs to fit the carb.
I got it running today, on break cleaner as I didnt have gas on hand.
Next issue:
Next issue:
- Adrian719
Last edit: 10 May 2024 14:35 by Adrian719.
- Adrian719
