- Thank you received: 8
Project KZ440 Scrambler
- BruceinOH
What kind of paint are you using? Do I see Duplicolor in the pic?
Thanks
- Adrian719
- Thank you received: 3
- Adrian719
The plastic as well as the outside of the gauges were faded so I gave them a quick coat of black, and clear gloss. I actually don't mind the faded gauge faces so.
Took the carbs apart. The PO used some silicon to try and seal the fuel bowls. It definitely needs new o-rings. Both diaphragms are soft, but one has a small tear in it so I'm going to replace both.
For now they are soaking in pinesol.
If anyone knows a good source for parts for these carbs let me know! Also I really don't want to reuse the airbox, so I may try some silicone radiator hose and pod filters in a sort of "H-pipe" configuration.
- BruceinOH
The jets were not OEM but I have seen recommendations for the brand on this site before, Keyster?. The gasket was a pain to keep in place but a few dabs of Vaseline held them in place. Next time I will use super glue as recommended on this site as well.
The kit does not have the pilot jet plugs but they do sell a Honda plug that supposedly fits.
- Adrian719
Unfortunately being in canada makes those sites a hit or miss. Shipping is just way too expensive.BruceinOH post=897947 userid=79126I ordered carb kits from Dime City.
I did find a local source for some stuff: www.partsnmore.com/parts/kawasaki/kz440d/?filters
It turns out both of my diaphragms have small tears in them. JBM industries wants $30us just for shipping, so I'm trying to find a cheaper alternative.
- Adrian719
My new handlebar, signals, and grips have arrived. I'm currently deciding if I want to paint the fenders green, or black. I'm also sort of trying to figure out if there's some sort of dirt style fender I can use.
- Rudapo
- Adrian719
Actually I was sitting looking at the fender yesterday thinking it needs to be shortened hahaha.before painting the front fender, if you're going for the scrambler look, shorten it! Looks more scrambler'ish
you can remove piece of the front and of the rear of the fender, i've done it with my 440 scrambler.
- Adrian719
- BruceinOH
I just realized last night the tires have tubes. I have been reading a lot of back and forth about going tubeless. What are you going to do? I ordered tubes this morning so I have them.
Also, did you use the same paint on the forks? You are looking a lot further along than me.
Thanks.
- !Seymore
- Ride on...
- Thank you received: 69
Quick question.
Tubeless mags didn't happen for a while... sorry I don't remember the year. But it's best to tube your tires, don't need a slow leak to sideline you during a ride.
C.
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
- !Seymore
- Ride on...
C.
