KZ650 Sleeper Build (KZ1000 engine transplant)
  • Injected
  • Injected's Avatar Topic Author
Re: KZ650 Sleeper Build (KZ1000 engine transplant)
29 Jul 2025 15:15 - 29 Jul 2025 15:16
#915241
I finished machining this drop shim for the RH muffler, got it installed and sealed the muffler to collector pipe joint with 3Bond sealant.
I also got the cam cover back on after marking the center idler bracket, its more than I thought at a .160" so its staying on the bike as is because the cam timing is set perfect. The cam end plugs are now sealed and hopefully there are no leaks to come.
Not sure if I want to mess with this down the road, but I do know I don't want to try a longer cam chain just to fix this small annoyance.
If anything I would just try a thinner billet shim under the current bracket and see if it will do the job. Timing the cams again is no big deal compared to swapping a cam chain just to make it easier to take the cam cover off.
Tomorrow I plan to put the coils on and start it when its cooler in the morning. I want to see if those leaner pilot jets were the right choice.
1978 KZ650B2 modified project
Last edit: 29 Jul 2025 15:16 by Injected. Reason: info
The following user(s) said Thank You: Nessism, Wookie58, kimchella
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
30 Jul 2025 07:42
#915275
Just spit-balling here but wouldn't it be relatively simple to brace the sides of the idler then remove the required amount from the top (space permitting)
The following user(s) said Thank You: Injected
  • Vinsky
  • Vinsky's Avatar
30 Jul 2025 07:52 - 30 Jul 2025 08:01
#915276
I bolted the idler to piece of aluminum then cut the top off and lowered it to the same height as the sprocket then welded it together. Doing it like this doesn't change cam timing or amount of chain adjustment.
Vinsky
Last edit: 30 Jul 2025 08:01 by Vinsky. Reason: error
  • SWest
  • SWest's Avatar
  • 10 22 2014
30 Jul 2025 07:53
#915277
I was thinking lowering the engine by removing the long bolts and using a small floor jack 1/2" might be the easiest way to remove the cover. Lots of room in there when they are out.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
30 Jul 2025 08:01
#915279
I bolted the idler to piece of aluminum then cut the top off and lowered it to the same height as the sprocket then welded it together. Doing it like this doesn't change cam timing or amount of chain adjustment.  I posted a photo of the mod here but don't see it now.
Indeed, this was just an alternative way to achieve the same outcome but may give more clearance given the frame/engine combo here.
  • Nessism
  • Nessism's Avatar
30 Jul 2025 08:22
#915286
I have no opinion on the idler, but I can say that I've been reading every post recently, waiting for a test ride report!  This bike is just SO COOL!  Hope you get it running to your liking, Injected!
  • Injected
30 Jul 2025 11:17
#915293
I started the engine this morning and right away it sounded much crisper, but the plugs are still rich. When I stopped to put the ColorTune plug on it I had a hard time getting it started again even though it was warm. I had the old battery on there when I did my compression test and it may have been a bit weak.
I am hoping its just a air screw setting, so once I swap out the battery to get it started again I should know where I am at as far as pilot jetting. There would be no harm in taking it for a test ride as is, just black spark plugs.
It did this same hot start thing the last time I had it running, no issue with starting from stone cold.
I still need to fix the petcock orientation and handle length before I can take it for a test ride.
The following user(s) said Thank You: Nessism, sf4t7, Wookie58, kimchella
  • Injected
30 Jul 2025 11:22 - 30 Jul 2025 13:01
#915295
I came up with the same conclusion the other night...
Just need to check the cam cover internal dimensions to make sure it clears. This design keeps everything the way it is except clears for the interference at the top, plus no dowels or loose pieces to worry about.
No dropping the engine to take the cam cover off, there is only 1/16" of clearance from the engine case to the bottom frame rails on this conversion.
Last edit: 30 Jul 2025 13:01 by Injected. Reason: pic
The following user(s) said Thank You: SWest, Wookie58
  • Injected
04 Aug 2025 11:19 - 04 Aug 2025 11:20
#915509
I was able to get this bike started today on the new battery. Fully charged it was 13.1 V after sitting a few days off its trickle charger.
Started the engine with the #20 pilot jets and the air screws backed out 1 turn, no issues on cold start. Revved it up to above 3000 RPM and it was backfiring so I stopped it.
Put the Color Tune plug on it and restarted with no issues, plug showed specs of lean so backed the air screw off till the color was light blue. That ended up being 3/4 of a turn. Set all the carbs to 3/4 turn out, then took the Color Tune off for the real plug.
Restarted with multi meter clips on the battery, noticed the battery was down in volts, revved it to 4000 RPM and had no backfires but the battery only read 13.2 volts.
I stopped the engine and read the battery at 12.7 volts, either the regulator or the stator is not charging the battery. The battery is running down pretty quick after starting it several times.
The engine is starting better on the new battery but I could easily wreck it riding with a non functioning charging system. I have to look into this further before I venture out for a test ride as I don't want to get stranded.
Last edit: 04 Aug 2025 11:20 by Injected. Reason: sp
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
04 Aug 2025 11:28
#915511
Sounds like you’re getting there
  • Injected
04 Aug 2025 11:46
#915512
Yes, jetting seems to be close so I am just going to leave it for now even though the plugs are still black. I really need to ride it tho, get some real heat thru the engine then revisit the pilot settings but for now at least I know it would make it down the block.
Both the regulator and stator are used parts so I need to conduct further testing to see where the failure is.
The following user(s) said Thank You: Wookie58, kimchella
  • SWest
  • SWest's Avatar
  • 10 22 2014
04 Aug 2025 13:21
#915513
I suggest testing if there's a short in the windings and the block. Test each of the three wires to block to see if one is shorted. Each of the stators I had one leg was shorted. One of them was a new aftermarket. I found one at eBay that wasn't before I bought it. That was two years ago and it's still working fine.
