- Thank you received: 2301
Project: 1990 ZR550 Zephyr (yes, another one)
21 Jul 2023 10:45 #887478
by Wookie58
Replied by Wookie58 on topic Project: 1990 ZR550 Zephyr (yes, another one)
Your third wire is a straight ground (which may not have suited the relay you had) so if it works ok without having this wire connected to the relay you are using now - happy days
The following user(s) said Thank You: Stereordinary
- Stereordinary
- Thank you received: 143
23 Jul 2023 20:54 #887528
by Stereordinary
A breeze from the west.
‘90 ZR550 Zephyr
Replied by Stereordinary on topic Project: 1990 ZR550 Zephyr (yes, another one)
I took the bike out for a ride today. Only ten miles, very conservative, about 45mph top speed. Tried to focus on slow movements and just really feeling everything.
With the throttle open past the idle jets it feels smooth, relatively linear predictable power. But below 2k rpm’s it’s like the tach has a mind of its own. From one stop light to the next it might decide to idle higher or lower. And the throttle feels like it has heaps of mushy free play despite being adjusted to spec this morning.
My theory is that the PO rejetted the carbs for pod filters. This is an easy assumption because when I got the bike there was a lot of parts in bins, including the carbs, and they were fitted with pods when I found them. There was also a Factory Pro jet kit in there.
So I think the obvious thing to do is see if I have the original jets and get them back in there. It looks like maybe I do, but im not entirely sure how to identify OEM versus aftermarket jets, and where to purchase replacement OEM jets if I need them.
‘90 ZR550 Zephyr
- gd4now
- Denco where did you go?
- Thank you received: 431
24 Jul 2023 12:46 #887544
by gd4now
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Replied by gd4now on topic Project: 1990 ZR550 Zephyr (yes, another one)
Keihin jets will have a "K star" and some type of number on them. At least the ones I have seen did. As to locations to find real jets, I am sure others will chime in, but there are several online locations one can find them. You might try jets r us for starters and check other locations as well.
1977 KZ650 B1
- Thank you received: 2224
24 Jul 2023 18:51 #887565
by TexasKZ
Replied by TexasKZ on topic Project: 1990 ZR550 Zephyr (yes, another one)
If you don’t mind pods, the Factory Pro stuff is high quality.
- Stereordinary
25 Jul 2023 08:56 #887586
by Stereordinary
‘90 ZR550 Zephyr
I’m kind of neither here nor there about pod filters. I’ve seen them look good on some bikes, but just an eyesore on others. Some CR carbs with velocity stacks on the other hand…
‘90 ZR550 Zephyr
- Stereordinary
25 Jul 2023 09:13 #887588
by Stereordinary
‘90 ZR550 Zephyr
Yesterday I took the carbs out, and found that it had the needles and main jets from the Factory Pro kit installed. I put the OEM ones back in, and readjusted the pilot jets to 2-1/2 turns out.
While I had them out, I took the time to install a manual cam chain tensioner.
Overall I feel like this made a difference in stabilizing rpm’s in the low range. However it is still prone to idling too high, and when I adjust it lower, it goes back up again. And when I do get it down around where it should be, it has a galloping kind of gurgle, almost like it’s running on three cylinders. I am wondering if maybe I need to install the proper spark plugs. The PO put in NGK D8EA’s but the stock should be D9EA’s.
Also I still feel like the throttle has that mushy unresponsive sort of feel. Is it possible to dial out the throttle free play entirely?
‘90 ZR550 Zephyr
- gd4now
25 Jul 2023 11:29 #887596
by gd4now
1977 KZ650 B1
With the stock mains and needles are you still using pods, or did you install air box and filter? I would think with pods and stock settings it would be lean, as pods should flow more air than the stock air box/filter will.
1977 KZ650 B1
- Stereordinary
25 Jul 2023 13:14 #887598
by Stereordinary
‘90 ZR550 Zephyr
I’ve got the stock airbox in.
‘90 ZR550 Zephyr
- Stereordinary
05 Aug 2023 09:15 #887976
by Stereordinary
‘90 ZR550 Zephyr
I’ve been riding the bike a bit, it’s now got about 60 miles on it since I got it running. It’s very cold-blooded and takes longer to warm up to a smooth idle than my other bike. But eventually it does feel like things are running smoothly. However there’s still a few things that need ironing out, and I have some concerns.
Here’s a strong vibration that I only feel at about 6100 to 6600 rpm’s. It does it in every gear. I have no idea what would cause that, other than maybe some kind of resonant frequency thing. But my other bike doesn’t do it, so I am curious.
I’ve got an oil leak on the left hand side. I feel like it’s probably just a bad gasket. Perhaps the previous owner installed a non-OEM cheap-o gasket. I know for sure the cam cover gasket is crap as I installed that myself (bought it from eBay listed as OEM, but I’m pretty sure it’s not, already bought a replacement). While it does seem like some of the leak is coming from there, I think there may be another coming from under the cylinder block.
And finally, I am perplexed by the manual cam chain tensioner. I have manual cam chain tensioners installed on both bikes, but one sticks out with room to go in way further than the other one. I followed directions for installation to a T, but given what I’m seeing I feel like one of them has to be wrong.
Photos just because.
‘90 ZR550 Zephyr
- howardhb
- God, I trust
- Thank you received: 469
05 Aug 2023 09:34 #887977
by howardhb
'81 GPz 550 D1
'81 GPz 1100 B1 ELR "Tribute" www.kzrider.com/our-forum/11-projects/61...-elr-tribute?start=0
'82 Yamaha YB100 Fizzie
Replied by howardhb on topic Project: 1990 ZR550 Zephyr (yes, another one)
The cooling fins on your Bronze / Gold Zephyr cylinder head look uber cool!
H.
H.
'81 GPz 550 D1
- Stereordinary
22 Aug 2023 14:50 #888587
by Stereordinary
‘90 ZR550 Zephyr
‘90 ZR550 Zephyr
- slayer61
- KZR FLAG RELAY CARRIER #62
22 Aug 2023 15:17 #888588
by slayer61
Replied by slayer61 on topic Project: 1990 ZR550 Zephyr (yes, another one)
Start with a clean .. really clean bike/engine and pay really close attention?
The following user(s) said Thank You: Stereordinary, Wookie58
