Rebuild of KZ1000J engine
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: Rebuild of KZ1000J engine
05 Oct 2022 12:44
#875108
Aha, never seen those. Do you have a picture of a P frame with them installed?
They are installed in this picture (corners would normally be square) these braces are factory on the "P" from early 80's
  • Jonas_Z1000j
  • Jonas_Z1000j's Avatar Topic Author
05 Oct 2022 13:42
#875113
ah, of course. Thats a good spot, should be invicible also once assembled. I will look into it! thanks for the advice!
Z1000 J2 -82 not so running restoration object anymore
Z900RS -21 Green/Yellow
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Away
  • Moderator
  • Moderator
05 Oct 2022 14:25
#875114
Moved to Projects
DD
The following user(s) said Thank You: Jonas_Z1000j
  • Jonas_Z1000j
08 Oct 2022 10:33 - 08 Oct 2022 10:33
#875265
Today I have had a great Kawasaki-day, to my familys joy. Riding Kawasaki, washing Kawasaki and welding Kawasaki I still dont know what this will cost me, but im happy unaware for now.
Got my cylinder back yesterday, +0,5 mm and a little milled to get it sealing properly. Sanding and painting is next:
Then I added extra braces as Wookie kindly pointed out, Police Interceptor style (sounds really cool )!
Unfortunately it was 10 years since I last welded something, very well. I have heard that powder coating is really thick
I will leave it together with the stands, battery case and engine mounts etc on Monday.
About powder coating, will it cover most imperfections on the frame or should you prepare the most visable parts with sanding before?
Another thing that came to my mind. The engine dampers, they are expensive... put in new ones or not?
Last edit: 08 Oct 2022 10:33 by Jonas_Z1000j.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
08 Oct 2022 10:42
#875266
Powder coating will cover more than paint but ultimately " the better the prep, the better the finish"
  • blackozvet
  • blackozvet's Avatar
09 Oct 2022 23:07
#875326
The thickness of the powdercoating depends on who is doing it.
If its important best to just discuss it with the powdercoater first.
Some coaters can put it on fairly thin and make it look like paint.
1973 Z1 900 Kawasaki
  • Skidmark
  • Skidmark's Avatar
10 Oct 2022 08:04
#875356
Average powder coat thickness is .003" to .006", and varies by how the powder is applied.  If hand sprayed, it will be dependent on the operator's technique.  Thickness can be controlled better by automated equipment, but that is better suited to flat surfaces and not complex round tube structures (like frames).  Prep is your best bet to get a good looking finish as the coating will follow and show all contours.  I thought some of the areas on my frame were good enough only to be disappointed with my prep after I got it back.
Retired gearhead
'81 KZ-750 E2
  • Jonas_Z1000j
23 Oct 2022 10:02 - 23 Oct 2022 10:04
#875864
Still waiting for my frame from the powder coater I have been polishing covers and as in any DIY restorers career, I have tested electogalvanizing at home (not sure its the correct term).
But I must admit, for fasteners with some light rust on them, it actually works quite nicely.
From a Swedish motor magazine I have followed this procedure:
1. Clean them good, finish with brass wheel
2. Put them over night in citric acid bath (keep it room tempered or more). The acid removes rust and the old coating, giving them a matt dark grey finish.
3. Some more brass wheel if needed, then soak in solvent. dry.
4. Put them in vinegar/salt/suger bath and hook them up to a zinc anode with a current of approx 0,015 A per cm2.
Unfortunately no before pics, but half of these where in bad condition, under the battery tray etc. the others had some light rust on them.
The process leaves a matt finish that one can polish up with the brass wheel. See the 2 big washers for example.
I think its quite cool! Hopefully most m6 and m8 that does not support critical things can be restored this way, then I can just source NOS items where original is missing or in really bad condition.
Anyone has any experience with this?
Last edit: 23 Oct 2022 10:04 by Jonas_Z1000j.
  • Jonas_Z1000j
01 Nov 2022 04:59
#876263
I got the frame back from the powder coater today, wohoo! very happy with results.
Color is semi gloss:
What do you think?
The thick paint covers most imperfections. I cleaned the more visable welds before I handed it in, and that is something I can recommend, as the debris really pops out otherwise.
Other than that I also sourced  a new left side panel with all mounts intact as well as the seat lock. Also a NOS handle cover is on the way.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
01 Nov 2022 05:12
#876264
Looks good, just need to "pop it back together" now
  • Jonas_Z1000j
02 Nov 2022 00:20 - 02 Nov 2022 00:24
#876294
Yep Im struggling with myself though, what level to put this project on. Im trying to remind myself that this was intended as an cam chain replacement project and that the bike "should be in good working order with no visable rust".
For exampel, a fastener that before looked good, like OK condition 40 years old, now looks really old compared to the engine and frame. Especially the chrome ones that cant be refinished easily.
I am working on a cart from cmsnl of som NOS fasteners for the more visable ones to start with. It should be easy to replace later on, if I want to bump up the finish.
Edit. An an advice if you are leaving the frame for powder coating, dont let the fasteners protrude past the hole, It took a couple of hours for me to remove them because some had such thick layer of paint on them.
Last edit: 02 Nov 2022 00:24 by Jonas_Z1000j.
  • hardrockminer
  • hardrockminer's Avatar
02 Nov 2022 12:18
#876305
You can get a complete set of screws from this source.  They also sell all the hex head nuts and bolts but not in a kit.  Pick up some Vessel JIS screwdrivers as well.  They are impact drivers.
www.japanmotonuts.com/
