And finally, Wookie's 82 begins !
Re: And finally, Wookie's 82 begins !
04 May 2024 10:55
- Cra-z1
04 May 2024 11:08
In general I like surprises but not that kind
04 May 2024 11:21I'm telling myself that the PO lost the correct bolts and the only ones he had where "too long"In general I like surprises but not that kind
- sf4t7
04 May 2024 15:29
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
04 May 2024 15:44
04 May 2024 16:16
04 May 2024 16:21I am staying optimistic that is was a "bolt" issue
The following user(s) said Thank You: Injected, Rolf1976_KZ900
04 May 2024 18:24
I am surprised those new bolts Dod not interfere with the cam cover
- Kelly E
04 May 2024 18:40
Nice job on the engine hoist.
We usually just lay the motor on the right side and lower the empty frame over it. The only thing on the frame is the center stand so we can stand it up right away.
Like the others said at least they used metric bolts. On our 80' Suzuki GS 1100E the two center exhaust ports have each had both holes fixed using 5/16" SAE Helicoils. The two outer ports still have original metric threads. We converted it over to studs so now it has 4 - 8mm x 1.25 studs and 4 - 5/16" x 18tpi studs, what a pain.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
1983 Honda CB 1100F
And more
- Rolf1976_KZ900
05 May 2024 05:04
Have you had the camcap off to check if it is helicoiled ? Was it on this engine you made studs for the caps?
05 May 2024 07:43Not yet Rolf, I just dropped the cover off for extra clearance when removing the motor. I will be using "stud and nut" to remove the caps as it's the kindest to the threads. The studs are simply a tool for diasasswmbly and reassembly as they would be too long to be a permanent fixture. The advantage of doing this is there is no pressure on the bolts until they are fully "in" so less risk of pulling threads. (I have used this method previously on other motors)Have you had the camcap off to check if it is helicoiled ? Was it on this engine you made studs for the caps?
The following user(s) said Thank You: Rolf1976_KZ900
- Rolf1976_KZ900
05 May 2024 09:00
aha now i understand thanks for explaining.That was a smart way to do it.
