The Free Z650F2
  • Bevelhead
  • Bevelhead's Avatar Topic Author
Re: The Free Z650F2
09 Mar 2022 08:00
#863460
Yes fitting a new speedo inside the housing is an option, though it'll be cheaper if I buy from somewhere in the UK.
  • 750 R1
  • 750 R1's Avatar
Re: The Free Z650F2
09 Mar 2022 13:47
#863487
I'm getting the speedhut speedo with the program button remote, Instead of on the screen, i'm going to fit it under the reset trip button so it all looks stock..
There was a Japanese company making a factory looking electronic speedo for the Z650 but they stopped making them a couple of years ago, I tried to find one for my sons 650...
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
Re: The Free Z650F2
09 Mar 2022 19:21 - 09 Mar 2022 19:26
#863508
I couldn't find a speedo drive to fit the 25mm axle i'm using up front, I'm going to use a 4 inch speedhut GPS speedometer and mount it inside the GPZ750A2 gauge housing, you may be able to do something similar, speedhut have sensor speedometers too.. They are customisable.
speedhut.com/gauge-application/classic-s...120mph-programmable/
Has anyone ever seen an electrical driver to use cable driven gauges with a modern electronic speed sensor?  That's a cool product idea. It wouldn't be that hard to make a little gizmo with a motor in it that mounted on the back of the gauge.
I guess I'm not the first one to think of this:
www.amazon.com/JEGS-Mechanical-Speedomet...-Built/dp/B07P6CR4T4
speedhut.com/accessories/sensors/speed-s...ive-speed-converter/
www.dakotadigital.com/index.cfm/page/pty...mode=prod/prd886.htm
malexmotorsports.com/collections/speedom...rive-speed-converter
My dad's '74 Z1
'00 ZRX1100
Last edit: 09 Mar 2022 19:26 by DOHC.
  • 750 R1
  • 750 R1's Avatar
Re: The Free Z650F2
09 Mar 2022 23:29
#863520
Interesting, I'm sure somewhere I've seen smaller motorcycle specific ones...Thanks for that...
  • Bevelhead
Re: The Free Z650F2
10 Mar 2022 16:16
#863554
One option for the speedo / tacho is just to fit a modern combined unit, along with either a GPS sensor or a magnetic sensor triggered from the front wheel. That would mean losing the classic duel Zed clocks, but I am considering fitting a small cockpit fairing which would hide most of the clocks from view anyway.
Meanwhile the R6 discs and calipers have been fitted to the forks, and now just need to make a spacer to replace the speedo drive which wont be needed anymore.  The fork mounts had to be milled down a few mm and the holes helicoiled to mount the bracket neatly. I was planning on painting the fork lowers black and having the brackets hard anodised black too, but could also just polish both.. decisions, decisions..
  • TexasKZ
  • TexasKZ's Avatar
Re: The Free Z650F2
11 Mar 2022 08:49
#863587
Would the electronic drive from a 1981 or later 1000/1100 LTD fit?
  • Bevelhead
Re: The Free Z650F2
11 Mar 2022 09:59
#863593
An interesting option, something I hadn't considered. Looking at the part, not sure if it would fit. Price on Ebay for a used drive is £80, so not something I would like take a risk with.
  • TexasKZ
  • TexasKZ's Avatar
Re: The Free Z650F2
11 Mar 2022 10:20
#863595
Wow! I had no idea they had gotten so expensive.
  • Bevelhead
Re: The Free Z650F2
28 Mar 2022 04:15
#864406
For the price of a packet of biscuits, a friend let me use his blasting cabinet to remove several layers of paint from the wheels, which saved me a huge amount of time. They will refinished in gold, not sure yet if I will paint them myself or get them powder coated.. the latter being more expensive but giving a more durable finish.
Meanwhile the frame has gone to be powder coated, and has been taken back to bare metal. Which showed some rust damage to the frame, which they will get repaired before powder coating the frame.
  • Bevelhead
Re: The Free Z650F2
08 Apr 2022 06:46
#865123
Spent ages polishing the fork lowers of the Z650, one of which had some deep damage.. suspect it must have fallen over on that side. Should've just painted them black really.
All the fasteners are polished stainless, with some, such as the top yoke nut and spacer coming an via Ebay supplier called classic_bike_fasteners .. excellent quality, and not much difference in price compared to the original chromed bolts from Kawasaki.
  • Bevelhead
Re: The Free Z650F2
10 Apr 2022 07:32
#865204
Collected the frame and various parts.. battery box, electrics panel, headlight mount, from the powder coaters, Triple S. They did an excellent job as always. Once blasted, rust holes were found in the 'ears' towards the back of the frame. These were fixed by a man Triple S use, then the frame could be powder coated. I left the wheels to be powder coated next, in a satin gold finish, along with some machined parts that are getting a new finish for me.. Cerakote.Also collected some engine parts for my Z1000 Mk2 project. All good, but prices have gone up recently, no doubt heating their big ovens must be getting expensive..[img] i.imgur.com/1FG8k4D.jpg[/img ]
  • Bevelhead
Re: The Free Z650F2
15 Apr 2022 12:36
#865517
2nd try at posting photo
