My 73 Z1 all done
- Robb2018
- 76 KZ900 73 Z1 A
Re: My 73 Z1 all done
02 Oct 2021 07:26Just measured the bars... they're 4" rise. If my memory serves me correctly, the European Z1 and KZ900s came with 2" bars and the US had 4". Anyone know for sure about that?Wow! What a difference you've made! That old stator cover looks terrible!
No need to remove anything to change the swingarm bolt. When you pull it out simply put a similar bolt, like a front axle bolt or even a cheater bar in place to hold it while you withdraw the bolt.
Those bars appear to have a higher rise than stock bars. Is it just the way the photos were taken? I agree on the ty-wraps. Partzilla sells OEM wraps identical to the originals. Kawasaki used short ones on the bars.
KZ900; Z1
- slmjim+Z1BEBE
02 Oct 2021 07:44John Brooke's book indicates there was a low bar (PN 46006-013) available in the Euro market as an option for the '75 Z1-B model year. No indication there was availability any earlier.Just measured the bars... they're 4" rise. If my memory serves me correctly, the European Z1 and KZ900s came with 2" bars and the US had 4". Anyone know for sure about that?Wow! What a difference you've made! That old stator cover looks terrible!
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
The following user(s) said Thank You: Robb2018
- BCScott
02 Oct 2021 07:54
Looks fantastic. You should be very proud of the work you've done.
Back in the saddle and loving it! KZ1000A1
- MauiZ1
02 Oct 2021 10:40
Very nice, gives me hope for my project. I've got a long way to go.
- Robb2018
- 76 KZ900 73 Z1 A
02 Oct 2021 12:17 - 02 Oct 2021 12:24
MauiZ1 post=856079 "Very nice, gives me hope for my project. I've got a long way to go."
Not many things as fulfilling to me as taking a big pile of rusty junk and making a beautiful classic out of it. A big set of hooters maybe... definitely.
KZ900; Z1
Last edit: 02 Oct 2021 12:24 by Robb2018.
- Robb2018
- 76 KZ900 73 Z1 A
02 Oct 2021 12:29Just switched the swing arm axle around. It did shift because I couldn't find anything close to the diameter of the axle to hold it in place but it was easy enough to move the arm around to line it back up again.It looks really nice!
I saw a couple of things you may want to do. First, the swingarm bolt goes from right to left. The nut should be on the left side. Second, there should be two cable ties on each side of the bars.
KZ900; Z1
The following user(s) said Thank You: hardrockminer
- MauiZ1
28 Nov 2021 15:15
Still running well?
im making progress on my 73. Still a long way to go.
- Kidkawie
- I bleed premix
28 Nov 2021 18:20
Nice job!
If you're going restoration, I made a diagram of where all those wire and cable straps go. I think theres only 2 or 3 sizes.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- MauiZ1
29 Nov 2021 10:18
I know the harness tie location and size are indicated in John Brookes book.
29 Nov 2021 10:25
Stunning bike, be proud.
- u.k. Dave
Last edit: 03 Dec 2021 07:46 by u.k. Dave.
