1973 Z1 Maui
- 73z1
Re: 1973 Z1 Maui
22 May 2022 04:07My guess, the new bearing shells were not perfect, never seen this problem, I always check the cam spins free.Went through all the bearing locations one at a time with the other end supported by a lower half shell. I learned that three locations were pinching the split. Two on intake, one on exhaust. I lightly eased the very edges of the split on the caps and head, just like removing an edge burr. This fixed the problem, cams move easily now when fully assembled.
this begs the question, why now?
Newest project, camshafts and two bearing caps missing.
- MauiZ1
Re: 1973 Z1 Maui
22 May 2022 14:29
Obviously checking cam clearance with measuring tools and plastigauge is a must but I wonder about one thing. Aside from my specific problem I’ve suffered, let’s say you have good condition cams and new stock bearings. What if the clearance is somehow out of spec? I don’t think there are over or under size bearings available.
I’m going to replace these bearing shells and get a set of cams and I’ll of course do all the checks, hopefully the numbers come out ok.
Re: 1973 Z1 Maui
22 May 2022 15:09
I guess with no other size bearings available you would have to remove a little material from the back of the bearing (the coating isn't thick enough to risk scraping the face - how it was done a very long time ago) to relieve tightness. don't know how you could reduce clearance for a loose fit without a big spend (build the cam up with hard weld and regrind to spec)
Re: 1973 Z1 Maui
23 May 2022 04:52
If you checked the cams, why are you going to replace them? Were they damaged when the bearings turned?
- MauiZ1
Re: 1973 Z1 Maui
24 May 2022 14:32
There were a few spots that are damaged, I don’t think I should use them. They do measure near the top of the tolerance, if I could find a shop that could resurface them and stay above the minimum they are usable. I imagine it would require some pretty nice grinding equipment, there is only one machine shop here, I may ask them.
- MauiZ1
Re: 1973 Z1 Maui
24 May 2022 15:11
I’m thinking an 8 or a 16 finish. Going down to a 4 might be too good and not pick up enough oil
- zed1015
Re: 1973 Z1 Maui
25 May 2022 05:27 - 25 May 2022 05:28Hopefully you have found the cause of your issues but i just spotted this statment i missed which you may want to check up on..
it has heavy duty studs but I don’t see how that could cause this, there are a lot of hot rod Z1s out there running HD studs.
The stud holes in the barrel casting taper in towards the center from each end leaving a raised casting flash midway down..
In some cases there is quite a restriction in that area when fitting the larger diameter HD studs that can severely restrict oil flow to the cams and has been known to cause cam and cam bearing damage.
I always bore the four outer holes straight through with a 12mm drill to ensure sufficient clearance and oil flow.
You don't get this issue with the stock stud due to their reduced shank diameter ..
Last edit: 25 May 2022 05:28 by zed1015.
The following user(s) said Thank You: slmjim+Z1BEBE, Mikaw, Rick H., Wookie58
Re: 1973 Z1 Maui
25 May 2022 05:32Hopefully you have found the cause of your issues but i just spotted this statment i missed which you may want to check up on..
Zed1015 is this still relevant to the later “J” motor
- zed1015
Re: 1973 Z1 Maui
25 May 2022 05:46Yes! It's relevent to them all and worth checking.Hopefully you have found the cause of your issues but i just spotted this statment i missed which you may want to check up on..
It's just a result of the way the stud holes in the blocks are cast and they don't drill them through.
It's not an issue with stock stud because even if the 10mm threaded end only just slips through there'll be enough clearance around the reduced shank.
With the HD studs the diameter is the same all the way down so that's where the tapered casting can cause problems.
- Rick H.
Re: 1973 Z1 Maui
25 May 2022 06:00
Thanks for the info Zed, I never heard of this before you clued us in on it.
Rick H.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
- MauiZ1
Re: 1973 Z1 Maui
25 May 2022 07:41
Thank you, that is a great tip, I will surely do this, still waiting on some parts to assemble the top end.
- blackozvet
Re: 1973 Z1 Maui
08 Jun 2022 19:35
Howdy, now I can comment, have been lurking and following your build - keep it up !
1973 Z1 900 Kawasaki
