1973 Z1 Maui
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
Re: 1973 Z1 Maui
26 Aug 2021 05:15
#854360
Consider soda blasting?  It dissolves in hot water.
Let the part soak in very hot water for 1/2 hour or so.  If the water is agitated it speeds dissolving of the soda particles.  Rinse very thoroughly with directed water stream, like a hose nozzle on jet setting.  Repeat.
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
  • MauiZ1
  • MauiZ1's Avatar Topic Author
Re: 1973 Z1 Maui
26 Aug 2021 09:17
#854370
The paint is mostly off, I'm making plywood blanks now. I tape over the critical surfaces and then put the blank on. I'm plugging all the threaded and other holes. I'll get photos of the parts when they are ready, it's tedious.
  • MauiZ1
Re: 1973 Z1 Maui
26 Aug 2021 22:08 - 26 Aug 2021 22:10
#854398
I’m blanking the upper case, last piece. Each piece is taped off to keep out glass beads and covered with the wood to protect the tape. Bolt holes have bolts in them. I’m hopeful this saves me a lot of cleanup. Internal passages are also plugged in case there is leakage.
Last edit: 26 Aug 2021 22:10 by MauiZ1. Reason: Insert attachment
  • hardrockminer
  • hardrockminer's Avatar
Re: 1973 Z1 Maui
27 Aug 2021 04:31
#854400
When I had my stuff done I only blanked the cylinders and I used duct tape over them.  Otherwise I left everything open.  Immediately after blasting I used a water hose to thoroughly wash each piece and then compressed air to dry.
  • ghostdive
  • ghostdive's Avatar
Re: 1973 Z1 Maui
27 Aug 2021 04:53
#854402
Looking good. Advice I've heard suggests putting the blasted parts in hot water and spraying all the passages with compressed air - I suppose you can't be too careful.
2001 ZX-6R
  • MauiZ1
Re: 1973 Z1 Maui
27 Aug 2021 14:27
#854416
Yes, I must admit I’m maybe overly concerned but I will be dunking, blowing, checking with a flashlight in a dark room and anything else I can think of to assure myself there are no beads left in it.
  • MauiZ1
Re: 1973 Z1 Maui
01 Sep 2021 08:21
#854683
I'm almost ready to paint the frame. In the mean time, I'm thinking about replacing the case bolts. The old ones are a bit beat up and at least 2 were missing.
I don't see any sets on line. There was one but the vendor represented stainless as NOS.
Has anyone seen any sets from vendors I've missed?
  • Mikaw
  • Mikaw's Avatar
Re: 1973 Z1 Maui
01 Sep 2021 11:55 - 01 Sep 2021 12:00
#854689
I was real happy with these set for all the JIS cover screws. As for the case bolts I dressed up the heads of my original and had them replated. Sorry I can’t help with a set for the bolts. kaylinator gets credit for finding KMCarburetor
Last edit: 01 Sep 2021 12:00 by Mikaw.
  • hardrockminer
Re: 1973 Z1 Maui
01 Sep 2021 12:02
#854690
This guy is in Japan.  He has screw kits but not bolt kits.  He sells bolts though.  I've bought quite a few from him.  I highly recommend his products.
www.japanmotonuts.com/screw-kits
The guy's name is Frederic.
  • Mikaw
  • Mikaw's Avatar
Re: 1973 Z1 Maui
02 Sep 2021 17:39
#854752
No eBay APP ID and/or Cert ID defined in Kunena configurationIf your still looking
  • MauiZ1
Re: 1973 Z1 Maui
03 Sep 2021 08:25
#854772
Frame is painted. Looking at other parts, found a stiff link in the cam chain, I will surely replace it as well as a few parts of the tensioner. Most were renewed in 2009 and don't have much miles. The support shafts are the modified type with small cutaways but I think one is not renewed.
  • MauiZ1
Re: 1973 Z1 Maui
03 Sep 2021 19:21
#854786
Looking to get a rolling frame together. I’m finding tires difficult to find, one or the other vintage tire is out of stock most places.
I want rib front, block rear.
I put the restored choke plungers back in the carbs today, that should make a big difference next time it runs, the idle mixture screws made no difference. I had Robert Meggitt in the UK fix them, great looking work, prompt too.
I’m going to replate at least the 8mm case bolts, maybe most of the 6mm, I still need some new ones coming from Fastenal because some were missing.
