Project Sharkey, 1978 KZ650C2
- rstnick
Re: Project Sharkey, 1978 KZ650C2
15 Apr 2021 06:59 - 15 Apr 2021 07:01
The steering damper is mounted to the frame using a Heim joint.
It's screwed in where the yellow reflector screws in.
Have taken a picture I will post shortly...
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 15 Apr 2021 07:01 by rstnick.
15 Apr 2021 08:04Hi Nick, would you have a pic of the steering damper mount you used on the frame, I'm just about to fit a damper to my sons 650 and are looking at mount solutions..
Why? Ed
- 750 R1
15 Apr 2021 14:57 - 15 Apr 2021 15:00
Hi Ed, I know from reading previous posts of yours you don't think they are needed, yes the 650 is very stable, I have fitted dampers to every bike I've owned that didn't come stock with them. Have you ever had a tank slapper ? I have, one bad enough to dent my tank with my thumb, broke the steering lock tab on a 750 Honda back in the early 1980's at speed, frightened the poop out of me, have used them ever since, Think of them as an insurance policy...
Besides this is my sons first bike, just being over cautious...
Thanks Nick, the damper I have has heim joints at both mounts, I'm interested in what you put between the frame and the mount on the damper, The hole in the frame puts the damper to close to the engine if not using something to bring the mount further out, does that make sense ?I was considering using a short piece of tube with a bolt welded in one end and a nut welded in the other....
Last edit: 15 Apr 2021 15:00 by 750 R1.
15 Apr 2021 17:17 - 15 Apr 2021 17:17I asked because some folks believe they are a cure for speed wobbles even though the speed wobbles may be an indication of a serious problem that needs to be addressed. My 1977 KZ650 developed bad speed wobbles several years back. The problem ended up being bad Michelin Macadam tires. I found the problem after replacing the swing arm bushings, steering stem bearings, shocks, etc., etc. Replacing all those items slightly dampened the problem, but replacing the tires made the problem absolutely go away at any speed. It appears that the bike in question does not have any wobble so the damper is not being installed to try to correct an existing problem; that's good. That's why I asked. EdHi Ed, I know from reading previous posts of yours you don't think they are needed, yes the 650 is very stable, I have fitted dampers to every bike I've owned that didn't come stock with them. Have you ever had a tank slapper ? I have, one bad enough to dent my tank with my thumb, broke the steering lock tab on a 750 Honda back in the early 1980's at speed, frightened the poop out of me, have used them ever since, Think of them as an insurance policy... Besides this is my sons first bike, just being over cautious...
Last edit: 15 Apr 2021 17:17 by 650ed.
- Skidmark
15 Apr 2021 19:07
I am going to run a damper on my KZ750 because they are good at smoothing out steering inputs during transitions from one direction to the other. I had one on an earlier bike and loved the change in feeling on the steering. Don't use them as a cure for poor handling, but rather for an improvement during aggressive riding/racing.
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
- 750 R1
16 Apr 2021 02:11I get where you're coming from Ed. The 650 has new stem bearings, wheel bearings, brakes, it uses my 750R1 forks that were completely rebuilt just before I bought it, {pulled them down to check them and found everything perfect}, which was a pleasant surprise, new rear brakes and all set up almost right, I need a little more preload in the front forks but apart from that, it rides and stops very well, actually I'm impressed just how well these 650's handle. I'm definitely not trying to hide any handling gremlins....I asked because some folks believe they are a cure for speed wobbles even though the speed wobbles may be an indication of a serious problem that needs to be addressed. My 1977 KZ650 developed bad speed wobbles several years back. The problem ended up being bad Michelin Macadam tires. I found the problem after replacing the swing arm bushings, steering stem bearings, shocks, etc., etc. Replacing all those items slightly dampened the problem, but replacing the tires made the problem absolutely go away at any speed. It appears that the bike in question does not have any wobble so the damper is not being installed to try to correct an existing problem; that's good. That's why I asked. EdHi Ed, I know from reading previous posts of yours you don't think they are needed, yes the 650 is very stable, I have fitted dampers to every bike I've owned that didn't come stock with them. Have you ever had a tank slapper ? I have, one bad enough to dent my tank with my thumb, broke the steering lock tab on a 750 Honda back in the early 1980's at speed, frightened the poop out of me, have used them ever since, Think of them as an insurance policy... Besides this is my sons first bike, just being over cautious...
- rstnick
16 Apr 2021 11:19
Here's a picture of the Heim joint threaded directly into the frame where the reflector used to be.
There's a lock nut to keep the Heim joint in one spot.
I also have steering dampers on my bikes because I like the feel of them, and the added stability they give.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
The following user(s) said Thank You: 750 R1
- 750 R1
16 Apr 2021 14:50
Thanks for the pic Nick. The bracket that goes on my damper has the heim joint in it so i'll have to fashion up a small bracket between it and the frame...
- rstnick
18 Jun 2021 18:45
Have close to 1000 KMs on Sharkey so far this season.
Been to a few Meets:
Yesterday I balanced the carbs, CVK32s.
They were all over the place on the synch tool to start, but some adjustments brought them all to the same level, balanced.
Took a test ride and she is running even better.
Still waiting on my painter to finish the bodywork and fairings.
Some other bikes at the Meets:
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- 750 R1
19 Jun 2021 17:05Please Log in or Create an account to join the conversation.
- rstnick
23 Jan 2022 07:52
Does look like Pinocchio with the headlight way out front.
My painter buddy is not going to have the fairing and bodywork done come this Spring, so have decided to put regular handle bars on and move the headlight back to the original position.
I did find riding her last season was uncomfortable with the low Clubman style handle bars.
I will get this gas tank repaired and painted to match these side covers and tail.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- rstnick
23 Jan 2022 07:57
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
