New to me 1982 305 CSR!
- ghostdive
Re: New to me 1982 305 CSR!
11 Apr 2021 13:03
Put simply, I'm very stupid sometimes. It started raining after I got the front on and the temperature dropped. I had a blow dryer handy but it didn't do as much as I'd hoped.
Suppose I'll pick up some real tire lube this time too.
2001 ZX-6R
2001 ZX-6R
11 Apr 2021 15:47 - 12 Apr 2021 05:25
If you're using a lubricant, even dish soap, I doubt that's the problem. But I don't know that much about changing tires as I've only done a few. maybe head over to youtube for some videos. ???
Last edit: 12 Apr 2021 05:25 by martin_csr.
11 Apr 2021 16:59
This might be obvious, but once you get the tire started and it’s starting to get tough to lever over the rim, make sure the point of the tire 180degs opposite the tire iron is pushed into the center of the rim at its smallest diameter.
The following user(s) said Thank You: ghostdive
- ghostdive
11 Apr 2021 17:22
The first set I put on my 750 were no problem, but it was like 95 and sunny. Thanks for the centering tip, I'll make note of that.
2001 ZX-6R
2001 ZX-6R
