kawasaki turbo speedo drive
  • just wont start
  • just wont start's Avatar Topic Author
13 Jan 2021 16:13
#841684
Hi does anybody know if the kawasaki turbo speedo drive is the same as the normal 750 or the 1100 ? I know the wheel is the same !
Regards
  • TexasKZ
  • TexasKZ's Avatar
Re: kawasaki turbo speedo drive
13 Jan 2021 21:12
#841690
If you are asking about the gear case, it was used on a bunch of models. Take a look at the Related Fitment list — www.partzilla.com/product/kawasaki/41078...cce842e25cd8afa045a0
The following user(s) said Thank You: just wont start
  • martin_csr
  • martin_csr's Avatar
14 Jan 2021 06:56 - 15 Jan 2021 06:02
#841697
Some of the earlier speedo drives have the exact same components as the 750 Turbo. Only obvious difference I can see is the Turbo's is painted black.
Last edit: 15 Jan 2021 06:02 by martin_csr.
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
18 Jan 2021 08:05
#841922
I went through this exact situation on Saturday...
My Mrs' bike forks are OEM '81 GPz11 forks.
Added '84 GPz 750 wheels.
Add into the mix the original speedo on her GPz is the stupid electronic one.
The OEM electronic drive didn't mate up with the '84 GPz wheel.
Forgive my lack of memory, but details escape me, but IIRC the OEM electronic speedo drive had large "tabs" and small "valleys"
The "84 wheel has the same set of small valleys and large tabs. This combo didn't allow the large tabs on the speedo drive to fit the small valleys of the '84 wheel...
Back to evilbay.
  • martin_csr
18 Jan 2021 10:25
#841937
He didn't say exactly what model, so I just assumed the 83 750 Turbo which has a typical KZ mechanical speedo drive gearbox.
  • slayer61
  • slayer61's Avatar
18 Jan 2021 10:53
#841941
martin_csr wrote: He didn't say exactly what model, so I just assumed the 83 750 Turbo which has a typical KZ mechanical speedo drive gearbox.
No worries Martin. I was just sharing a similar experience.
  • martin_csr
19 Jan 2021 05:37 - 19 Jan 2021 05:38
#841997
ha ha. okay. That was just my way of asking the op what motorcycle he has. The 750 is the only stock turbo I'm aware of.
not a 750.
Last edit: 19 Jan 2021 05:38 by martin_csr.
