kz750 frame compatability
  • Cloonster
  • Cloonster's Avatar Topic Author
11 Oct 2020 20:41
#836668
So I got this kz750 1976 I believe but I got no title and just wondering if anyone would know what frames would be compatible, it's a twin kz750. Any help would be appreciated, this is my first Kawasaki.
  • TexasKZ
  • TexasKZ's Avatar
Re: kz750 frame compatability
12 Oct 2020 06:29 - 12 Oct 2020 06:29
#836685
I am pretty sure the only compatible frames are going to be other 750 twins. Might be easier to just get a title for what you have. If you are in the U.S., it may be easy. In some states it is easy, in others not so much. If you live in a difficult state, getting a Vermont title first might be the ticket.
If you live outside the U.S., then I do not know. At any rate, it would pay to check with your local department to find out just what you need.
Last edit: 12 Oct 2020 06:29 by TexasKZ.
The following user(s) said Thank You: Cloonster
  • martin_csr
  • martin_csr's Avatar
12 Oct 2020 06:34
#836686
The best match would be the 76-79 750B models. For swapping the engine I'm pretty sure you can go with any KZ750-Twin frame, since the motor was pretty much unchanged thru the entire model run. The 83-84 750K models were belt drive & I have no idea if that would be an issue.
