1977 KZ1000 Restomod
- DOHC
- Those Doe-Hawks really go!
Re: 1977 KZ1000 Restomod
07 Feb 2022 13:47Do you know if that's a shunt style regulator (like the OE part) or a series regulator like the HSH775?Just wondering if it's worth the trouble with the Ricks reg/rec that I'll be using.
If it's a shunt regulator, any time the generator is making more energy than you are consuming, the regulator turns that excess energy into heat.
So the answer to how hot it gets depends very much on what else you put on the bike as a load.
If you end up with mostly efficient LED bulbs, for example, that would tend to make the regulator run hotter.
If you fit a 100W halogen headlight maybe that takes load off of the regulator and allows it to run cooler.
In any case, given that it has big cooling fins on it, it probably makes sense to give it some airflow.
'78 Z1-R in blue
, '78 Z1-R in black,
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
The following user(s) said Thank You: ThatGPzGuy, calum
- calum
07 Feb 2022 21:02 - 07 Feb 2022 21:04It's a Ricks 14-515. Not sure what flavour it is - couldn't find any details on the website.Do you know if that's a shunt style regulator (like the OE part) or a series regulator like the HSH775?
Yeah, that was my thinking. I guess I was just hoping someone would come along and say that it's unnecessary - would've made things a bit easier.In any case, given that it has big cooling fins on it, it probably makes sense to give it some airflow.
KZ1000 Restomod (
2000 BMW F650GS
2000 BMW F650GS
Last edit: 07 Feb 2022 21:04 by calum.
08 Feb 2022 01:00
Worth a conversation with the manufacturer, the alloy plate it is bolted to will act as a “ heat sink” and radiate the heat but it may not be enough?
- calum
08 Feb 2022 07:36Dunno why I didn't get in touch with Ricks straight away They got back to me within about thirty minutes and said it shouldn't be a problem. From his answer it was clear that it would be better underneath though. I'll tape it to the bottom an see how it looks just bolted straight to the tray - if I recess the tray I may run out of room for the wiring, breather tube etc.Worth a conversation with the manufacturer, the alloy plate it is bolted to will act as a “ heat sink” and radiate the heat but it may not be enough?
KZ1000 Restomod (
2000 BMW F650GS
2000 BMW F650GS
- DoctoRot
08 Feb 2022 11:16 - 08 Feb 2022 11:17
I had my Ricks RR under the tail for a few years before it melted, when it did it was an exceptionally hot day - 105F. You will probably be fine, but I moved it behind the carbs for more airflow to not have to shell out another $130.
Last edit: 08 Feb 2022 11:17 by DoctoRot.
- Oysteinaar
09 Feb 2022 11:59
What if you turn it 90°? That way you will get airflow/cooling between the ribs through the hole in the frame:
Kawasaki KZ650 1979
- calum
09 Feb 2022 13:12
That hole at the front won't be there when I'm done. That's why I was planning on recessing the underside and bolting it on the bottom (will mount it sideways as well). If I recess the bottom to much I'll run out of room for the wiring etc. though. Thinking of just putting about a 15-20mm step in the plate so the rectifier is at least partly covered.
KZ1000 Restomod (
2000 BMW F650GS
2000 BMW F650GS
- calum
11 Feb 2022 13:22
Side stand switch sorted. Took some advice from the old man and rotated it a bit. It's a lot smoother now.
KZ1000 Restomod (
2000 BMW F650GS
2000 BMW F650GS
- calum
19 Feb 2022 10:44
Trying to get the electrics sorted. Cut out a section of the try to recess the rectifier - will mount it under the try to avoid any potential overheating. I also cut out a bit of 6mm plexiglas for the middle section. I'll put a bunch of helicoils in the plexiglas for the electrical components and also to mount it to the tray.
KZ1000 Restomod (
2000 BMW F650GS
2000 BMW F650GS
19 Feb 2022 11:23
Looking tidy Calum
- calum
20 Feb 2022 12:02 - 20 Feb 2022 12:07Thanks. Put in some of the helicoils today and made a bracket for the starter relay. The relay is sitting up pretty high in the photo but I'll get some pan head screws for the bracket and it will drop down a bit. May still be too high in which case it will be moved back towards the battery. Good thing I don't need too much foam on the seat for this bikeLooking tidy Calum
KZ1000 Restomod (
2000 BMW F650GS
2000 BMW F650GS
Last edit: 20 Feb 2022 12:07 by calum.
- DOHC
20 Feb 2022 14:41
If the solenoid doesn't fit under the seat, I wonder if you could find a place to mount it next to the starter motor and oil pressure switch. The wiring wouldn't be quite as clean since you'd have to run the coil wires down there, but it seems like you'll have a harness path from the engine up to the seat anyway so maybe it doesn't look much different.
'78 Z1-R in blue
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
