- Thank you received: 208
1977 KZ1000 Restomod
- kzstreetfighter71
- Atlantic West Coast
- calum
- Thank you received: 415
I'll probably keep the electrics as is and leave the side covers on. I was contemplating an open cafe racer look (to show off the pods
I am thinking of shortening the tail the same amount as this build:
Attachment Umbau1.jpg not found
Source: www.kraftrad-kasberger.com
KZ1000 Restomod ( www.kzrider.com/forum/11-projects/614517-1977-kz1000-restomod )
2000 BMW F650GS
- kzstreetfighter71
- kzstreetfighter71
Attachment A93C1927-3DAC-415C-B44F-1FF088E06B49.jpeg not found
- Thank you received: 1852
- calum
kzstreetfighter71 wrote: The rear of my bike is extended out about the same and the red line is roughly where the frame ends, imagine the tail shortened and a modified seat, this will preserve the strength of your frame by keeping it uncut.
Thanks. I'm not worried about shortening the frame though as it will be a second frame that I am getting with the bike that has already been attacked at the back end. I'll also be getting the frame braced so strength shouldn't be a problem.
The main factor for the length of the tail section is German bureaucracy - the license plate cannot be more than 30° from vertical. Unless I go for a side mounted plate I'll need to go back as far as the picture I posted. As soon as I have everything in the garage I'll see where the limit is and mock up a few options.
Out of interest, did you chop off the rear indicator mounts?
2000 BMW F650GS
- kzstreetfighter71
No they were gone when i got the bike along with the passenger peg bracket and shocks. Previous owner had "bobbered" it. That term makes me shudder, even though i own a stripped down 71 shovelhead. The shock mounts have been repurposed for now as the indicator mounts. You will have to shorten your tail cowl regardless, i have an old one off her previous form thats all ready been butchered if you want one to mess around with with out ruining the one you have.calum wrote:
- calum
kzstreetfighter71 wrote: Previous owner had "bobbered" it. That term makes me shudder, even though i own a stripped down 71 shovelhead.
Know what you mean
kzstreetfighter71 wrote: i have an old one off her previous form thats all ready been butchered if you want one to mess around with with out ruining the one you have.
Thanks, that would be sweet. I'll send you a PM.
2000 BMW F650GS
- kzstreetfighter71
- DoctoRot
- Thank you received: 784
I had to extensively modify my Tarrozi rearsets to be compatible with the kickstart. the pedal and peg will get in the way.calum wrote:
A couple of things I'm not sure on:
- I'd like to do away with the battery and just use the kick-starter. I've read that this works with the Tarozzi rear-sets but I'm not sure how practical it will be. Are these things a pig to kickstart?
to reiterate what DOHC said - the higher compression pistons wont raise the dynamic compression when you add a long duration cam, most engines like to operate in a relatively small dynamic compression range. kick-starting a 12/1 piston with a long duration cam will be similar to kickstarting a 10/1 piston with a short duration cam as they likely will have very similar cranking compression.
- calum
Will be getting forks, triple clamp, clip-ons, swingarm to start off with so I can get the riding position sorted. Will probably get the wheels done too (maybe not the tires - no point in having them sit around for ages).
Getting a bit impatient, but have enough to do until I pick up the bike in a few weeks.
2000 BMW F650GS
- kzstreetfighter71
