1977 KZ1000 Restomod
- calum
Re: 1977 KZ1000 Restomod
03 Jan 2022 08:14
Good thing - there almost certainly aren't enough church windows in Ireland
KZ1000 Restomod (
2000 BMW F650GS
2000 BMW F650GS
- kzstreetfighter71
- Atlantic West Coast
03 Jan 2022 08:51 - 03 Jan 2022 08:51
HA yeaa we have a love of the church windows over here, i actually have something, that i will defiantly will not be using, what are you leaning to on the seat? i have a Zephyr1100 seat cover, brand new, was goin to use it for a project but changed my mind on it, yours if it is any good to you.
Last edit: 03 Jan 2022 08:51 by kzstreetfighter71.
- calum
03 Jan 2022 08:55
I won't really know what I need until the seat pan is done, but the seat will definitely be a lot shorter than the 1100 - will be a single seater. , don't want anybody on the back of this one.
Will almost certainly have to get the seat cover made, but thanks anyway.
KZ1000 Restomod (
2000 BMW F650GS
2000 BMW F650GS
- calum
11 Jan 2022 10:15 - 11 Jan 2022 10:16
KZ1000 Restomod (
2000 BMW F650GS
2000 BMW F650GS
Last edit: 11 Jan 2022 10:16 by calum.
- spdygon
16 Jan 2022 09:55
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
1974 Z1 900 project
- calum
16 Jan 2022 10:01
Time to get back to work!
KZ1000 Restomod (
2000 BMW F650GS
2000 BMW F650GS
- calum
20 Jan 2022 09:49
Got the frame back.
Did the back end myself - changed the brackets to a straight bar and just plugged the end of the tubes. Welds are a little bit better with the reading glasses.
KZ1000 Restomod (
2000 BMW F650GS
2000 BMW F650GS
20 Jan 2022 11:37
Looking good Calum
- Skidmark
20 Jan 2022 11:53
Being able to clearly see the weld puddle, and the seam, makes a remarkable difference in weld quality.
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
- Dr. Gamma
20 Jan 2022 14:11Just curious, have you installed the swing arm, the rim and tire you are going to use along with the shocks without their springs and check to make sure nothing will come in contact with your tire throughout the whole range of suspension travel??
1986 RG500G 2 stroke terror.
20 Jan 2022 17:40
The rear end upswept frame looks like to have a lot of space left for the suspention travel and tire/fender clearance.
- calum
20 Jan 2022 22:35 - 20 Jan 2022 22:49Just curious, have you installed the swing arm, the rim and tire you are going to use along with the shocks without their springs and check to make sure nothing will come in contact with your tire throughout the whole range of suspension travel??
I haven't taken the springs out but the clearance under the tail section would allow the springs to fully compress. I'll double check again later though, thanks.
KZ1000 Restomod (
2000 BMW F650GS
2000 BMW F650GS
Last edit: 20 Jan 2022 22:49 by calum.
