1978 KZ1000-A2 "Barn find"
  • Kaylinator
  • Kaylinator's Avatar Topic Author
Re: 1978 KZ1000-A2 "Barn find"
30 May 2020 16:24
#826960
cb900f wrote: That seat tho...... :evil:
I can't wait to get rid of that thing. I think it was taken from a '76 or '77 as the pan doesn't have the hook for the seat catch.
1978 KZ1000-A2
1978 KZ400-B1
2022 Z900RS SE
  • 9er rider
  • 9er rider's Avatar
  • Keep a cool tool
30 May 2020 16:32 - 30 May 2020 16:39
#826962
The one in my 78 was like and sounded like sitting on a bag of potato chips it was a real Kawakup
Last edit: 30 May 2020 16:39 by 9er rider.
  • Kofla
  • Kofla's Avatar
30 May 2020 17:44
#826968
Amazing, the bike needs work but seems like a great project. Can't believe the other two people weren't interested at this price.
1978 Kawasaki KZ1000 LTD
2010 Kawasaki Ninja ZX-14
  • Kaylinator
30 May 2020 18:04
#826970
Rick H. wrote: You could break those brackets by simply walking into them by accident, or trying to use them to muscle the bike around in the garage. I am glad you decided to try to bring this bike back to life. No doubt it will cost you some money and time, but in the end it will be well worth the effort I think and the personal satisfaction will no doubt be enormous. Besides, $500 for this bike would have been robbery.
Rick H.
For sure it's going to cost me money. Browsing for parts online I keep thinking "oh that's not too bad" until I remember that's in USD and the Canadian dollar is garbage right now.
1978 KZ1000-A2
1978 KZ400-B1
2022 Z900RS SE
  • Kaylinator
30 May 2020 18:05
#826971
Kofla wrote: Amazing, the bike needs work but seems like a great project. Can't believe the other two people weren't interested at this price.
They were certainly interested. Just didn't want to deal with the wrath of their wives if they brought home *another* bike.
1978 KZ1000-A2
1978 KZ400-B1
2022 Z900RS SE
  • Rick H.
  • Rick H.'s Avatar
30 May 2020 18:14
#826972
You may be right about their wives, but I would be kicking myself severely for letting your bike slip through my fingers for a mere $500.00!
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
  • Mikaw
  • Mikaw's Avatar
30 May 2020 18:30
#826974
May I make a suggestion. Get the bike running first. Make sure there is nothing major wrong before fixing turn signals. It’s not a bad thing though while your sorting out the major components I.e. engine and brakes, to go over the bike and make a list of items that need to be addressed. One thing I’d suggest is checking the combustion chambers and confirm the are clear of criter stuff, nuts, nest, and such. Once that is confirmed, pull the plugs and start adding small amounts of oils every few days to start knocking out the rust before you attemp to kick it over. Make sure you do your due diligence to thwart off new critters. Keep the intake, exhaust, and plug openings sealed up in between oil baths.
Keep in mind your starting with a really complete bike that beyond sentimental cost you have very little cost upfront. I have seen this bike sell for 6-8 k. It’s worth the sweat equity and cost to revive it.
The following user(s) said Thank You: Kaylinator
  • Kaylinator
30 May 2020 18:43
#826975
Mikaw wrote: May I make a suggestion. Get the bike running first. Make sure there is nothing major wrong before fixing turn signals. It’s not a bad thing though while your sorting out the major components I.e. engine and brakes, to go over the bike and make a list of items that need to be addressed. One thing I’d suggest is checking the combustion chambers and confirm the are clear of criter stuff, nuts, nest, and such. Once that is confirmed, pull the plugs and start adding small amounts of oils every few days to start knocking out the rust before you attemp to kick it over. Make sure you do your due diligence to thwart off new critters. Keep the intake, exhaust, and plug openings sealed up in between oil baths.
I'm not ordering a single part until I can get this thing running. Just tinkering and making a list right now. We are pretty confident she'll fire up. I started to pull the exhaust the other day so I could take a peek and make sure they were clear, but the nuts needed another soak first.
1978 KZ1000-A2
1978 KZ400-B1
2022 Z900RS SE
  • SWest
  • SWest's Avatar
  • 10 22 2014
30 May 2020 18:53
#826976
Put a little oil in each cylinder before you try to kick it over. Cost me $500+ due to dry starts.
  • 9er rider
  • Keep a cool tool
30 May 2020 19:11
#826977
Ive found the electrical connectors can get to be brittle and corroded, Diablo Cycle was a great help
  • Mikaw
  • Mikaw's Avatar
30 May 2020 20:03
#826980
Good course of direction. Be careful when removing the side covers. The grommets might be hard. Try to reach to the back of the mounting tabs and push them out instead of pulling on the covers. Also keep all factory parts, even if you plan to upgrade. Example would be the air box... they are expensive to replace and even harder to find...
I went back and looked at the “washed” bike. Cleaned up really well. What did you use? Looks to have removed most of the corrosion and crud.
  • Kaylinator
31 May 2020 09:00
#827001
Mikaw wrote: Good course of direction. Be careful when removing the side covers. The grommets might be hard. Try to reach to the back of the mounting tabs and push them out instead of pulling on the covers. Also keep all factory parts, even if you plan to upgrade. Example would be the air box... they are expensive to replace and even harder to find...
Unfortunately the side grommets are all toast. My brother apparently rolled it out a few years back to see if it would start, and wasn't exactly gentle.
Plan is to keep everything as stock as possible. Was originally going to do pods until we found the air box silencer on the other end of the farm yard. $300 on eBay?!?!
I just sprayed the bike down with super clean degreaser, let it sit for a couple minutes, then rinsed it off with a weak pressure washer.
1978 KZ1000-A2
1978 KZ400-B1
2022 Z900RS SE
