The rusty hulk
  • Mikaw
  • Mikaw's Avatar
Re: The rusty hulk
06 Jun 2020 13:54
#827467
Your a frickin animal, the speed you did that is amazing. Nice job.
  • calum
  • calum's Avatar
Re: The rusty hulk
06 Jun 2020 17:09
#827483
I agree, not even a month later and ready to ride. Nice work.
  • hardrockminer
  • hardrockminer's Avatar
Re: The rusty hulk
06 Jun 2020 18:10
#827498
Looks a lot better than when you first bought it!!
  • ckahleer
  • ckahleer's Avatar
  • Online
Re: The rusty hulk
06 Jun 2020 18:47
#827500
Do you sleep?
94 KE100
82 KZ305
85 VF1100c
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Away
  • Moderator
Re: The rusty hulk
06 Jun 2020 19:14
#827503
If you have the time and / or are retired . Anything is possible.
Lets all stand by for his next project
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
Re: The rusty hulk
07 Jun 2020 05:38
#827509
Well done, and done quick!
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
Re: The rusty hulk
07 Jun 2020 05:50
#827510
  • JR
  • JR's Avatar
Re: The rusty hulk
07 Jun 2020 06:10
#827513
the ugly duckling became a swan !
Beautiful bike
The following user(s) said Thank You: Barry1
  • 73z1
  • 73z1's Avatar Topic Author
Re: The rusty hulk
18 Jun 2020 10:53
#828384
I can see the air screw from the back side of 73 carbs (no brass jet blocking view)
I cannot see the air screw from the back side of 75 carbs, there is a brass jet blocking the view.
Is this normal ?
#1 plug is black with 73 carbs (cleaned twice and replaced plunger).
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
Re: The rusty hulk
18 Jun 2020 11:40 - 18 Jun 2020 11:42
#828388
Do you have any pics? I am a little confused about your description :unsure: :unsure: :unsure:
Last edit: 18 Jun 2020 11:42 by Scirocco.
  • slmjim+Z1BEBE
Re: The rusty hulk
19 Jun 2020 05:53 - 19 Jun 2020 05:55
#828446
There is a brass idle air jet at the mouth of the venturi on the later VM28's circa late '74Z1 and all '75 Z1, the ones with the small drain screw. The brass jet is just upstream of the idle mix screw. The orifice of the brass jet is fairly large, guessing .035 or so if calibrated eyeball isn't failing. Should be able to see a tiny portion of the tapered end of the idle mix screw using good light & maybe some magnification.
The earlier earlier VM28's circa '72 through late '74 Z1, the ones with the large drain plug, have no brass idle air jet.
Note that Mama Kaw/Mikuni changed the taper of the idle air screw concurrent with the myriad of other changes made to the late-74/all '75 VM28's.
Good Ridin'
slmjim & Z1BEBE
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
Last edit: 19 Jun 2020 05:55 by slmjim+Z1BEBE. Reason: Typo
  • 73z1
Re: The rusty hulk
19 Jun 2020 09:57
#828462
This is a 73 carb, you can see the air screw.
