Clutch cable
18 Oct 2019 15:47 #812690 by Joel488
Clutch cable was created by Joel488
I recently got a 81 kz350 csr I got it running but the clutch cable is junk I was wondering if anyone else has found one online that works
19 Oct 2019 09:09 - 20 Oct 2019 06:00 #812710 by martin_csr
Replied by martin_csr on topic Clutch cable
What do you mean it's junk? Also, does your motorcycle have the stock handlebars?
Clutch adjustment. On some models you're supposed to turn the clutch release adjusting screw counterclockwise first until hard to turn, then clockwise 1/4 turn. It's kind of counter-intuitive & some manuals are ambiguous as to the direction.
My 1981 KZ650-CSR is counterclockwise first >> the 305-CSR has the same adj. screw.
Last edit: 20 Oct 2019 06:00 by martin_csr.
