KZ 550 LTD Cafe
- Joe320
KZ 550 LTD Cafe
29 Sep 2019 17:55 - 29 Sep 2019 17:58
Hey guys I currently just bought 1982 kz550 C Limited and I'm hoping to turn it into a cafe racer. One of my questions is does anyone you know how I can lower the front forks by chopping the spring, the only thing is that I have air shocks. Or should I just bite the bullet and install gsxr forks, looking to build this bike on a strict budget.Any thoughts or ideas would definitely help thank you
Last edit: 29 Sep 2019 17:58 by Joe320. Reason: Added more
Re: KZ 550 LTD Cafe
29 Sep 2019 19:52
You can raise the fork tubes in the triple clamps a bit. You may also be able to put a lowering spacer in the forks that reduces their extension.
- loudhvx
Re: KZ 550 LTD Cafe
29 Sep 2019 20:11 - 29 Sep 2019 20:13
If you chop the springs too much and don't make up the difference with a spacer, it can unload at full extension and you will get a lot of rattle.
I chop the spring to get a stiffer suspension and then make up the difference with a spacer. It all ends up a little taller than stock, so it's probably not what you want.
Like Texas said, it would be better to raise the forks in the clamps by about 1/2" to 1". That will lower the front end by that much. The problem, as you mentioned, is that the air holes won't line up anymore. Will the air holes at least get blocked? I find it's better to use a slightly stiffer spring (I do it by cutting), then use no air. Then there's no stress about getting the pressure equal etc.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 29 Sep 2019 20:13 by loudhvx.
