Saving a '81 KZ750-E
Re: Saving a '81 KZ750-E
21 Aug 2020 15:02
definitely knocked the ugly off.
- Skidmark
21 Aug 2020 17:25 - 21 Aug 2020 17:30
Three coats are on. The temp readings inside my shop are 87 F, 15% humidity. Each coat flashed off really well in these conditions. As far as appearance goes, I am very happy with this paint. Whether or not it does well in operational heat, or just assembly handling, we will see. It won't be touched for at least 48 hours. The holding points of the stand will need touch up, but the top end will come off first. Each part still requires a final cleaning on the inside prior to assembly.
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
Last edit: 21 Aug 2020 17:30 by Skidmark.
- Skidmark
24 Aug 2020 10:08
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
- calum
24 Aug 2020 12:46
Looking good! That finish will look good with the rest of the bodywork.
KZ1000 Restomod (
2000 BMW F650GS
2000 BMW F650GS
- Skidmark
25 Aug 2020 09:16
I am on the hunt for the two shift shaft seals that press into the chain cover. Partzilla shows them in the diagram as # 92049E, but they only list A thru D. Anyone have another source for these two press in seals? I did not have any success searching Z Enterprises, either. Thanks in advance!
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
- calum
25 Aug 2020 09:35 - 25 Aug 2020 09:38
No eBay APP ID and/or Cert ID defined in Kunena configurationMaybe not much help, but I got mine from CMS. They should also be in any engine oil seal kits (they are definitely in the SFK kit I got on eBay and I haven't had any leaks yet...)
EDIT: here's the kit I got:
KZ1000 Restomod (
2000 BMW F650GS
2000 BMW F650GS
Last edit: 25 Aug 2020 09:38 by calum.
- Skidmark
25 Aug 2020 11:14
After a thorough cleaning, I found the clutch cable bracket on the actuator is cracked. Looks like a weld repair is in order.
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
- Dr. Gamma
25 Aug 2020 12:11 - 25 Aug 2020 12:21Skidmark wrote: I am on the hunt for the two shift shaft seals that press into the chain cover. Partzilla shows them in the diagram as # 92049E, but they only list A thru D. Anyone have another source for these two press in seals? I did not have any success searching Z Enterprises, either. Thanks in advance!
I believe you are looking for part number 92051-005. Different number than the ones the Kz900/1000 use!!!
Very common seal. Kawasaki used that seal on numerous models over the years.
1986 RG500G 2 stroke terror.
Last edit: 25 Aug 2020 12:21 by Dr. Gamma.
- Skidmark
25 Aug 2020 12:44
Here is the repaired bracket. I usually don't post close ups of my welding (:dry: :laugh: :laugh: :laugh: ), but this one didn't come out too ugly.
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
- DoctoRot
25 Aug 2020 18:55looks good. I think if you polish the cam cover ends its will really sing
- Skidmark
26 Aug 2020 12:00
I have been on the fence in regards to the ends of the cam cover. I was going to mask them from paint, then decided against it. As of now, I am leaning toward leaving the ends painted. We will see where I decide to go before final assembly.
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
- Skidmark
26 Aug 2020 12:41
As I continue to clean, prep, and paint parts my mind tends to wander. From seeing some recent conversations on spark plugs it got me thinking. I am upping the compression on my motor from the stock 9:1 to 10.5:1. I also installed the Dynojet stage 3 kit, and will be using pod filters. A Delkovic 4 into 1 header. From what I have been reading/researching, it sounds like I should use a colder than stock plug. The manual calls for a NGK B8ES for my bike. Should I break in the motor using one step colder? Opinions?
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
