Saving a '81 KZ750-E
- Wheelhop
Re: Saving a '81 KZ750-E
15 Apr 2022 10:20
Great looking bike and I love your garage / shop!
Could you run a flexible vent pipe off your bike exhaust to the outside in order to test and tune in the cold weather?
1978 KZ 1000B (73 tribute)
1977 KZ1000 project
1976 KZ 900
1976 KV 75
1976 Honda Elsinore MT250
1974 Z1 900 project
1971 Honda CT70
2000 ZRX 1100
1977 KZ1000 project
1976 KZ 900
1976 KV 75
1974 Z1 900 project
1971 Honda CT70
2000 ZRX 1100
- Skidmark
15 Apr 2022 10:23
The thought crossed my mind, but I have another bike project (and several non-bike related projects) going on, so I just switched to some of the others for the winter.
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
- Skidmark
08 Jun 2022 20:13
I still haven't figured out why I am being so procrastinate about doing this carb synch... I got a fuel line long enough to use the stock tank, resting it on one of my wheeled wire shelves. I can use the same wire shelf to suspend the gages. I have a design in mind to make my own wrench instead of buying Kawi's special tools. I have warmed up the bike again and verified that I have solved all of the fuel leaks in the lines and carbs. Another nice point was I verified my tach is operating quietly now (one of the first test drive's problems). I guess after sitting for 28 years some things require some lubrication! Gotta finish the break in and post some video of it going down the road.
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
The following user(s) said Thank You: ThatGPzGuy, Mikaw
- Skidmark
16 Sep 2022 15:16
Finally giving the Green Monster some love. About frickin' time... I removed the steering damper so I can figure out a better mounting method, and utilize the full travel (it was binding right before full turn on one side). I also improved the amount of steering by removing some material on each side of the steering stops. Having guessed at how much steering angle when it was only a frame, I left some extra material for adjustment purposes. Moving the bike around is much easier now. I also rechecked the float levels. So it was time to start it and see how that helped. Yeah, it's been too long since this bike got any attention - so much so the battery needs charging to fire it up.
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
- Skidmark
19 Sep 2022 13:09
I am pulling the carb bank off again. #2 cylinder is not running right. It fouled the plug, which makes me think that cylinder is running rich for some reason. Time to recheck the float levels and make sure the needle and seat are clean. They should be as they were installed new during the rebuild, but you never know. The carb sync wrench is arriving tomorrow - I was going to make my own, but found a really good deal online for one so I bought it. Bound and determined to get this motor broken in before winter!
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
- DoctoRot
21 Sep 2022 11:53
Getting a bike running is one thing. Tuning it is a another. Ergonomics, suspension, carbs, etc. Dialing it in takes time.
The following user(s) said Thank You: slayer61, Skidmark
- Gertch
07 Oct 2022 06:51
First, Sorry for coming to this party late.
When I got my KZ750, PO told me #2 cylinder running rich. I traced it to the fuel valve. Gas leaking through vacuum line into the carb. I rebuilt the valve and it still leaked.
I ended up just swapping out for a Pingel valve. Problem solved.
I wanted to bring this up before you start chasing the #2 carb.
Wish I could remember half of what I've forgotten
'81 KZ750 E2
'81 KZ750 E2
07 Oct 2022 12:47
Thanks and welcome
Gertch
, this a common problem of vaccum accutated petcocks. The rubber diaphram gets a crack and sucks fuel into the vaccum port.
- Skidmark
08 Oct 2022 08:57
I noticed a bit of a fuel drip with the tank off and the valve set to "on". I tapped on the valve with the handle end of a screw driver, and the drip seemed to stop. Later it was back again. I did rebuild the petcock during the bike build, but sounds like a good place to eliminate a potential problem. I will spring for a Pingle and see if that helps. Thanks!
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
- rstnick
10 Oct 2022 06:24
I don't know the spacing of the mounting bolts on the 750E's petcock, but the KZ/Z650's is 44mm center to center.
I bought a Suzuki petcock, new, from Z1Enterprises.
Direct bolt on, and has been working great for many years.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- Skidmark
10 Oct 2022 08:06
I am going to call Pingle direct with the bolt spacing on my valve to see what they have. Their web site does not list any applications for my bike, so a call is in order.
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
10 Oct 2022 08:23
Not sure but you might need to modify the tank. Pingle has a round pickup screen and if your tank has the oval to match the OEM screen then you will need to ream the tank some.
