Saving a '81 KZ750-E
  • Nessism
  • Nessism's Avatar
Re: Saving a '81 KZ750-E
10 Dec 2019 17:19
#815197
I've restored at least half dozen sets of those Keihin's, during which time I learned a thing or two.
And speaking of that...be sure to inspect your float bowl overflow tubes carefully. They love to crack. It's not too hard to replace them so don't panic if they are. Also, be sure to remove the pilot screws; drill a hole in the cap and then thread in a screw which you can use as a lever to pull the cap out with Then make a small hook tool from a piece of wire and remove the spring, washer, and old o-ring before dipping the bodies to clean them.
  • Skidmark
  • Skidmark's Avatar Topic Author
10 Dec 2019 19:10
#815198
I already removed all the plugs. They came out really easily. Should I remove the bleed pipes? They are underneath the primary main jets - I just can't see any screw driver slot. The one I messed up and had to drill out, I ended up kissing the top of the bleed pipe with the drill bit.
Retired gearhead
'81 KZ-750 E2
  • Nessism
  • Nessism's Avatar
10 Dec 2019 19:27
#815201
Yes, remove the bleed pipes. Push them out from the carb throat side. Be sure to remove the pilot jets too.
  • Skidmark
12 Dec 2019 11:08
#815277
The frame, kick stand, motor mounts, battery tray, and a bunch of other brackets are off to the powder coater today! Might as well get those going while I tinker with the carb rebuilds. 8-D
Retired gearhead
'81 KZ-750 E2
  • Skidmark
12 Dec 2019 11:50
#815278
And yes, some of the float bowl overflow tubes are cracked. I was aware of the potential problem after reading some of the threads on these in the Carburetor forum.
Retired gearhead
'81 KZ-750 E2
  • Skidmark
13 Dec 2019 13:13
#815315
This overflow tube was split, and partially cracked around at the press line. Even being gentle, it snapped off flush. I managed to get the piece out with an easy out, again being very gentle.
Retired gearhead
'81 KZ-750 E2
  • Skidmark
14 Dec 2019 12:03
#815343
Using Nessism's tips, the new overflow tube set me back less than $2, and about 30 minutes.
Retired gearhead
'81 KZ-750 E2
The following user(s) said Thank You: JR, Nessism, Scirocco
  • Skidmark
14 Dec 2019 12:19
#815344
The new tank emblems showed up yesterday! Love getting new parts!
Retired gearhead
'81 KZ-750 E2
  • Skidmark
16 Dec 2019 09:27
#815470
Anyone have any tips on how to get a brake caliper piston unstuck? It's been soaking in penetrating oil for a few days now, but still won't budge... this is on the rear caliper.
Retired gearhead
'81 KZ-750 E2
  • DoctoRot
  • DoctoRot's Avatar
16 Dec 2019 10:22 - 16 Dec 2019 10:23
#815476
boil the whole caliper, and then pop it out with compressed air.
Last edit: 16 Dec 2019 10:23 by DoctoRot.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
16 Dec 2019 10:35
#815478
Sometimes pressured air into the brake line fitting did the job. If not a grease gun did a 40 times higher pressure.
  • Skidmark
16 Dec 2019 16:31
#815496
Yay!!! I got the frame and a bunch of parts back from powder coat today!
Retired gearhead
'81 KZ-750 E2
