New Engine Build
- Ariel96
New Engine Build
29 Oct 2018 12:52
Hey i have a 1979 kz650 that needs a new engine. Anyone have suggestions on a faster engine that will bolt in or use very little mods. 750's, 900's and 1000's would be great. Thanks
- baldy110
Re: New Engine Build
29 Oct 2018 18:28
Any 4 cylinder KZ750 engine will bolt right in. The 900 and1000 wil require frame modifications.
The following user(s) said Thank You: Ariel96
29 Oct 2018 19:07
The 1980 and 1981 750 should be easiest to install. On later years Kawasaki changed the engine mounts somewhat and added rubber mounts. To install one of those engines some frame mods would be necessary.
- Ariel96
29 Oct 2018 22:47
Do you know any other engines other than kz? I wouldn't mind slight frame mods. I've heard gxr750, ninja 900?
- scubaanders
30 Oct 2018 02:44
Nope.
GPX750, ZXR750, GPZ750/900 water cooled will require major sugery.
Stick with Ed's advice. 1980-81 KZ750 E or L engine.
/Anders
/Anders
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
- gordone
03 Nov 2018 14:57
I have 650 frame with 750 upgraded to 810 bigbore, alot of fun
Project:
Project:
- baldy110
03 Nov 2018 19:05
- gordone
04 Nov 2018 01:16
Love to follow your project
Project:
Project:
- zed1015
04 Nov 2018 02:12Ariel96 wrote: Do you know any other engines other than kz? I wouldn't mind slight frame mods. I've heard gxr750, ninja 900?
Anything will fit into anything else if you have the skill.
Oilcooled GSXR 750 ,GSF 650/750, Bandit 600/650 are the easiest to fit ( Been there, Done that ) as they leave plenty of room in the frame but you still need to change all but one of the engine mounts and then fabricate exhausts and use most of the Suzuki wiring etc.
As this site is KZR i personally would either go for a bigger 750 /1000 kwak motor or just go buy another bike as that would probably end up cheaper.
04 Nov 2018 06:02 - 04 Nov 2018 06:03zed1015 wrote: ............................. just go buy another bike as that would probably end up cheaper.
Exactly! Ed
Last edit: 04 Nov 2018 06:03 by 650ed.
