75 Z1 gas tank lid
  • Tim
  • Tim's Avatar Topic Author
75 Z1 gas tank lid
09 Jul 2017 11:21 - 09 Jul 2017 13:51
#766485
Just got my Z1, can't get the lid open. The latch is working , It's been sitting 30 years so I assume the rubber is sealed .
Ideas on getting it open?
Thanks
Last edit: 09 Jul 2017 13:51 by Tim.
Re: 75 Z1 gas tank lid
09 Jul 2017 16:51
#766517
Remove tank, turn it upside down, remove the petcock, pour some Liquid Wrench or PBBlaster or Marvel Mystery Oil through the petcock hole, and let it sit for a while to allow the penetrant to soak into and around the cap (filler hole) area. Penetrant may leak out around the cap, so use a soak rag under the cap, and apply fresh penetrant as needed.
Good Fortune! :)
  • Tim
09 Jul 2017 18:48
#766525
Thanks, thats what I though too. What I did was turn it upside down, use a straw and poured oil into the cap. KIinda the same thing. Hope it works.
  • TwoCam
  • TwoCam's Avatar
10 Jul 2017 04:51
#766541
I have a used cap if yours is the one with a latch not a key to open, the gasket is a little dry rotted....if you damage yours??has slight pitting . I do have a brand new latch/spring too.....somewhere...
The following user(s) said Thank You: GPz550D1, Tim
  • Tim
12 Jul 2017 16:45
#766799
Got it open. It was rusty in there. I used Metal Rescue, bought gallon at Home Depot for $25 Put most of it in there and filled the rsat w hot water, let it sit a day wow is it clean inside.
The following user(s) said Thank You: TwoCam
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
12 Jul 2017 18:22
#766814
It doesnt take much to get these bikes going, but there are some small things to look out for. Search this site, z-classik or any of the major facebook pages.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
The following user(s) said Thank You: Tim
  • 9er rider
  • 9er rider's Avatar
  • Keep a cool tool
13 Jul 2017 12:41
#766857
Hopefully the gas s shalak rinsed out so you could get an even etch.
