My '82 440 LTD
- vwrabbit
Re: My '82 440 LTD
04 Oct 2017 11:42
Looks like the larger hole that I repaired still has a tiny leak. Going to get some POR15 to seal the tank from the inside. Two steps forward, one step back.
1982 KZ440 former LTD
1975 CB125S
2006 VT600 VLX
1975 CB125S
2006 VT600 VLX
- vwrabbit
Re: My '82 440 LTD
07 Oct 2017 11:35 - 07 Oct 2017 11:37
Found the pinhole that I missed. Got the seat cover done. Repainting the parts of the tank that got messed up.
1975 CB125S
2006 VT600 VLX
1975 CB125S
2006 VT600 VLX
Last edit: 07 Oct 2017 11:37 by vwrabbit.
- vwrabbit
Re: My '82 440 LTD
15 Oct 2017 15:39 - 15 Oct 2017 15:41
1975 CB125S
2006 VT600 VLX
1975 CB125S
2006 VT600 VLX
Last edit: 15 Oct 2017 15:41 by vwrabbit.
- ajsfirehawk
Re: My '82 440 LTD
15 Oct 2017 15:47
Lots of progress. Have you had her out yet?
80 KZ1000 Z1 Classic
83 KZ1100 LTD
18 Z900RS
23 Mach 1
83 KZ1100 LTD
18 Z900RS
23 Mach 1
- vwrabbit
Re: My '82 440 LTD
15 Oct 2017 17:31
Quick spin around the block. It sputters when it gets warm and under load. Need to check timing and carbs.
1975 CB125S
2006 VT600 VLX
1975 CB125S
2006 VT600 VLX
- JR
Re: My '82 440 LTD
15 Oct 2017 18:32
Nice job. Especislly on the seat and rear end.
Hope you get the sputters sorted out
- vwrabbit
Re: My '82 440 LTD
24 Oct 2017 12:56
Thanks! Hoping to get some tuning done in the next few weeks.
1975 CB125S
2006 VT600 VLX
1975 CB125S
2006 VT600 VLX
- KiZee
- vwrabbit
Re: My '82 440 LTD
16 Nov 2017 09:26
Haven't taken any time to do any tuning. Pretty chilly also here in the 'burgh. Might not get to it until the spring.
1975 CB125S
2006 VT600 VLX
1975 CB125S
2006 VT600 VLX
- vwrabbit
Re: My '82 440 LTD
24 Sep 2018 05:23
Finally got back to this. Need to do a compression check. Since this had been sitting outside for years, might have some issues w/the right cylinder. Combustion doesn't feel as strong on that side compared to the left. Also need to check the float levels. It's running quite rich. With pod filters, it should be lean if anything. Also need to replace the padding on the seat. It's quite hard.
Once that's all worked out, I'll be tearing her down for a full repaint.
1975 CB125S
2006 VT600 VLX
1975 CB125S
2006 VT600 VLX
