1982 KZ750 Twin CSR Rebuild
- ric812
Re: 1982 KZ750 Twin CSR Rebuild
03 Aug 2017 16:58
Ok I have the timing governor cleaned, lubed, and reinstalled. Bike still hard to start, idles rough, sluggish rev and only goes to 4500 rpm at WOT. It runs with the choke off but will not stay running for more than a couple of minutes. Even after soaking the carbs for 24 hours in 50% solution of pinsol then blowing out with carb cleaner.
What am I missing? Would old diaphrams cause this (they were soaked in alcohol with wintergreen overnight and incould not find any holes) or how do I tell if the slides are opening properly.
Please any advice on where to start. I am going to put a timing light to check the advance . And I have a dwell teach if that would do any good.
1982 Kawasaki KZ750M Twin CSR
03 Aug 2017 17:27 - 03 Aug 2017 17:29
An exact adjustment of the points the ignition timing is a must do for a good running engine..
Last edit: 03 Aug 2017 17:29 by Scirocco.
- ric812
03 Aug 2017 17:52
The 82 kz750 twin has an electronic ignition. But i will still check the timing to make sure the timing is advancing correctly.
