- Thank you received: 2829
Retroactive KZ750E Project Thread
I switched to Imgur a couple years ago when PB started sticking pop-ups all over everything and slowed their site way down. Imgur is free, easy to use, and fast. Of course I keep photos on my own media in case Imgur decides to follow the PB example. Ed
- Thank you received: 2224
www.bestbuy.com/site/seagate-backup-plus...4503.p?skuId=2944503
TexasKZ wrote: Or if you need a bit more storage.......
Excellent point! In fact, using the Seagate product one can buy 15 terabytes of storage (3 * 5 tb) for the cost of one year's PB fee! Ed
www.amazon.com/Seagate-Backup-Portable-E...0/dp/B01LZP2B23?th=1
- Thank you received: 2059
NAS with Raspberry Pi cost under $100
- Thank you received: 2810
Scirocco wrote: $400/year, never. Buy a cheap NAS and a free DynDNS account and get free access to your pics world wide for $100 for a live span.
This is an option! For now I'm all set with Flickr though.
I've got plenty of home storage space, but webhosting is what I didn't have (thus the use of Photobucket and now Flickr).
- Thank you received: 1656
martin_csr wrote: Was it very difficult or time consuming restoring all of the photos in this topic?
Yes. Had to find the original photo, post on flickr, then come back and cut and paste each link. Photobucket has a better user interface compared to flickr. This site is quirky too since it reads each flickr/photobucket link as several links even when it's only one. Have to parse down the link to the bare minimum or the site will think you posted a lot more photos than you are.
In the end I've come to realize that the E2/3 bikes use a different tach than the E1 in that has a "headlamp" warning light built in. . The gauges for my bike have a black bezel around the face but some other bikes came with green bezel gauges. I found a NOS tach with a black bezel but the only speedo I could find has a green bezel. Guess I'll have to open up one of them to swap things around to get them to match. Later though...
Sorry for all the photo glare...
- Thank you received: 2738
- Ed_in_Miami
- Thank you received: 46
My hamfisted attempt at rebuilding my gauges left me with both broken needles...
I had to devise a crafty replacement, but definitely ended up with a NON-OEM look...
Nessism wrote: One of my last projects with this bike was to update the gauges. As shown earlier in the thread I cleaned up the housings and the gauges looked nice and all, however, the needles sort of wobbled around more than I liked. Did a deep dive on gauge part numbers and got all kinds of confused. Kawasaki used a couple different part number gauges which threw me for a loop. The 550's used the same size gauges too which increased confusion.
In the end I've come to realize that the E2 bikes use a somewhat unique tach that has the "headlamp" warning light built in. This gauge also uses a black gauge bezel inside the housing. The speedometer for my bike also has a matching black bezel. I found a NOS tach which is correct but couldn't find a speedo. The speedo I bought has a green bezel so the gauges don't match. Guess I'll have to open my new speedo and paint the bezel. It's just that I've got heartburn opening a NOS gauge that I paid so much for.
This is my build:
kzrider.com/forum/11-projects/600312-ano...rtment-build?start=0
There are many more like it, but this one is mine... news to come!
- old_kaw
- Thank you received: 269
Nessism wrote: One of my last projects with this bike was to update the gauges. As shown earlier in the thread I cleaned up the housings and the gauges looked nice and all, however, the needles sort of wobbled around more than I liked. Did a deep dive on gauge part numbers and got all kinds of confused. Kawasaki used a bunch of different part number gauges which threw me for a loop. The 550's used the same gauges on at least some years too which increased confusion.
That is just an amazing job you did on this restoration. I do agree with the brittle engine paint chipping and it kinda makes all the prep work that it takes to make things look this nice, all a waste IMHO. I used an epoxy appliance black rattle can on my seat pan and front master cylinder.. and it looks great when I open my seat, but my front master cylinder looks like crap.. again. It doesn't hold up to brake fluid.
I love what you did with the gauges. You pried these open, then resealed them again? I hate the thought, but have done it myself on a XS1100 I brought back to life. It is hard to get the rings back on, then made to look right. Any pointers on this? I need to disassemble my tach, and would love to find a way to modify my speedo into a 160mph instrument for obvious reasons.
1981 Kawasaki Kz1000K1
old_kaw wrote: That is just an amazing job you did on this restoration. I do agree with the brittle engine paint chipping and it kinda makes all the prep work that it takes to make things look this nice, all a waste IMHO. I used an epoxy appliance black rattle can on my seat pan and front master cylinder.. and it looks great when I open my seat, but my front master cylinder looks like crap.. again. It doesn't hold up to brake fluid.
Thanks for the kudos!
I pried open the original gauges and restored them. There are photos showing the process earlier in the thread; basically take a small screwdriver and pry a little at a time and work around and around. Took about 4 times around prying as you go. To seal them back up all you have to do is tap the ring back down. The gauge has a rubber seal to keep out water.
I haven't opened up the new gauges yet to fix the bezel color mismatch.
I can't advise on how to mod the gauge other than you may be able to transplant the guts of one gauge inside your original housings. If you go down that road please post some photos showing the process.
