- Thank you received: 2811
Retroactive KZ750E Project Thread
13 Jan 2017 09:44 - 04 Aug 2017 07:24 #752078
by Nessism
Replied by Nessism on topic Retroactive KZ750E Project Thread
Next was Kleenstrip Metal Prep as sold by Home Depot to eat off some of the rust.
Phosphate sauce doing it's thing. About 90% of the rust is gone. After a good water rinse my leaf blower was used for drying.
Last edit: 04 Aug 2017 07:24 by Nessism.
13 Jan 2017 09:47 - 04 Aug 2017 07:26 #752079
by Nessism
A wire wheel was next followed by coal slag blasting. The blasting was focused in the areas where there was old remnant paint and rust, and to rough up the metal for paint. In the past I used to use "play sand" for blasting, but a friend pointed out that the silica was bad for the lungs so coal slag was used hereafter.
Last edit: 04 Aug 2017 07:26 by Nessism.
13 Jan 2017 09:53 - 04 Aug 2017 07:30 #752081
by Nessism
Last edit: 04 Aug 2017 07:30 by Nessism.
13 Jan 2017 09:57 - 04 Aug 2017 07:33 #752082
by Nessism
Wheels, brake calipers, and handlebars were done in Gun Kote for the extra durable protection.
These parts were supposed to be "satin black" but there isn't much satin that I can see. They weren't bad to the point that I was going to redo them though.
Last edit: 04 Aug 2017 07:33 by Nessism.
13 Jan 2017 10:01 - 04 Aug 2017 07:35 #752084
by Nessism
Some photos of the first set of Keihin's that were done. I ran these for a while and then did an even better set that are on the bike now.
[/url]
[/url]
Last edit: 04 Aug 2017 07:35 by Nessism.
- Dr. Gamma
- Thank you received: 676
13 Jan 2017 10:03 #752085
by Dr. Gamma
1986 RG500G 2 stroke terror.
Replied by Dr. Gamma on topic Retroactive KZ750E Project Thread
I love what you did with your KZ750E. I followed your build for a long time. Congrats on making BOTM!!!! I built a KZ750E back in the early 80's. I used many of the same parts you did. The GPz feetpegs, and the oil cooler were the same exact parts that I used on my E model. Your build brought back more than a few memories.
I road raced mine in a few WERA endurance races back then. I parked it when the Honda Interceptor came out in '83. After that it became my primary streetbike. Gold wheels were my trademark back then as you can see in the one photo.
13 Jan 2017 10:03 - 04 Aug 2017 07:36 #752086
by Nessism
Hand controls were heavily weathered so bought a couple better units for parts off ebay. Took them all apart and cleaned/greased in innards. Fixed a broken wire here and there too. Good fun and nice change of pace compared to all the painting and messy work.
Last edit: 04 Aug 2017 07:36 by Nessism.
13 Jan 2017 10:08 - 04 Aug 2017 07:38 #752087
by Nessism
Petcock was next...
Bead blasted the body and replated the steel parts. Fortunately, Kawasaki still sells the internal guts for these things.
Last edit: 04 Aug 2017 07:38 by Nessism.
13 Jan 2017 10:11 - 04 Aug 2017 07:40 #752088
by Nessism
And speaking of plated parts...
Used a "copy cad" zinc plating kit from Caswell's Plating. I've got a power supply now instead of using a battery for power but you get the idea...
Last edit: 04 Aug 2017 07:40 by Nessism.
The following user(s) said Thank You: jayrodoh, Greybeard
13 Jan 2017 10:15 - 04 Aug 2017 07:43 #752089
by Nessism
Working on the gauges. Condensation behind the glass and corrosion on the outside bezel. Gently pried off the sealing ring and took the units apart. Going to bead blast the housing and repaint next.
Last edit: 04 Aug 2017 07:43 by Nessism.
13 Jan 2017 10:17 - 04 Aug 2017 07:44 #752090
by Nessism
Also cleaned up and clear coated the fork sliders and footpeg brackets. Bead blasted off the corrosion and rubbed them down with gray scotchbrite before shooting the clear.
Last edit: 04 Aug 2017 07:44 by Nessism.
13 Jan 2017 10:21 - 04 Aug 2017 07:46 #752091
by Nessism
Forks got new seals, Sonic springs, Racetech emulators, and of course new oil.
"Clocks" (for you UK guys) turned out nice.
Last edit: 04 Aug 2017 07:46 by Nessism.
