- Thank you received: 5
Retroactive KZ750E Project Thread
- JohnLuke
- 1982 KZ750N Spectre
Thanks!
- JohnLuke
Thanks!
- Thank you received: 2810
JohnLuke wrote: May I ask how you masked everything off? Right now we all I got masked off is the rims. I have them deflated with the bead down and masking tape to protect the tire from overspray. Of course I’ll cover the rest of the tire. What I really want to know is how you masked the threaded holes. I’m also wondering how well does the masking tape come off after the paint is dry? Do I need to worry about paint peeling? And as for the tire set up, does that sound like a good idea?
Thanks!
I use 3M blue painting tape for masking, but I didn't mask the frame a whole lot. Too lazy. To remove paint from threaded holes by chasing with a tap. If your metal is preped right the tape won't pull off the paint. It's always best to remove masking before the paint reaches full cure regardless; wait a few hours and then remove any tape.
There is a critical recoat time of 24 hours between when you lay down the epoxy primer and when you have to top coat. I usually do the primer one day and the color coat the next. You can shoot the color the same day as the primer if you want it's just a lot of spraying. I'm not sure how long to wait but think you will be okay after an hour or so. The directions for the material are available on the internet so always download the data sheet for any paint materials you are using and follow them.
- JohnLuke
- kevski
- Thank you received: 157
- JohnLuke
The seat hoop has some scratches from where I scuffed before. I wasn’t able to get that part cuz I was upside down.
As for the other parts I’m not sure.
Thanks!
- JohnLuke
- gordone
- Thank you received: 67
JohnLuke wrote: So the first time I painted I did it to light. So the finished product looked and felt horrible. So I scuffed everything up and sprayed everything again until the paint had enough time to build up and not run. Now it looks fabulous. It’s just on a few places where as soon as I moved the gun upside down it didn’t spray. So my question is, can I mask off or whatever every thing I don’t want repainted, scuff up the area I want to fix and the spray it? Of course allow enough time for the paint to build up and really shine. Here are some photos of what I need to redo.
Thanks!
Why do you not make protject thread?
Project:
- JohnLuke
- JohnLuke
Thanks!
JohnLuke wrote: As for masking, if I just mask off the area I need to scuff up and respray won’t that cause a ridge or something when I remove the tape? Maybe when you say mask off you mean something else. The reason I ask is because I’m running out of activator. Stuff is expensive and I don’t know where to buy it. I kinda feel like I need to decide what parts I want to respray because I feel o don’t have enough.
Thanks!
Yes, you will get a tape line...but it's just a frame so that won't matter very much. And if the tape line upsets you there is always color sanding and polishing that can be done.
