need some help its my first bike
- grnbluwhte
06 Jan 2017 13:14
hi guys i recently purchased a kz1000r its a bit of a mess but i got it for cheap, i turned the engine over with a spanner and it turns well, i was just wondering what other things i should look for before i attempt to start it all the parts are there . i want to get it started before i start with the cosmetics
1983 KZ1000R
- Nerdy
Re: need some help its my first bike
06 Jan 2017 13:21
Welcome aboard!
Two quick questions:
1) What is happening with the ignition?
2) Where are the carburetors?
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
- grnbluwhte
06 Jan 2017 13:24
i have the carbs off for cleaning and it seems like the PO changed the pickup coils and spliced it onto the wires from the ic unit
1983 KZ1000R
- peter1958
06 Jan 2017 13:29
First thing I would do is a compression test. And the oilcooler lines need to be run on top of the valve cover head in the middle before you run it.
www.kzzone.com/
06 Jan 2017 13:29
Since you say all the parts are there, I will assume that the carbs and other intake related stuff are outside the picture someplace, and I will pretend tnot to worry about all those wires hanging out.
It would be a good idea to check valve clearances since many owners ignore this really important item.
Be sure there is plenty of engine oil. If it looks really contaminated, change it. A few dollars worth of the proper oil is not worth saving if it risks serious damage.
A good battery is essential. Even a slightly dodgy one will not provide enough power to turn the starter and fire the ignition.
Clean, new gasoline.
If you are cleaning and ajusting the carbs, be sure to install an inline fuel filter. You will not want dirt and smegma from that old tank to crap up your newly cleaned carbs.
Be sure the sparkplugs look good.
Cross your fingers and sacrifice a goat.
Have your favorite beverage on hand to celbrate.
Probably some other stuf.
- peter1958
06 Jan 2017 13:30
What are the engine and frame numbers
www.kzzone.com/
- grnbluwhte
06 Jan 2017 13:36
its night where i am cant really check them now, but why would you need them
1983 KZ1000R
- peter1958
06 Jan 2017 13:40
thats the only way to know if its a 1000R or just a j model
www.kzzone.com/
06 Jan 2017 13:42
Welcome aboard! See the link below for info that should help you with your "new" bike. Ed
www.kzrider.com/forum/10-new-members/604...up-a-76-kz900#744289
The following user(s) said Thank You: grnbluwhte
- grnbluwhte
06 Jan 2017 13:48
i checked that a while back searched the forum ,went to zedder.com and checked the engine number falls in the range of the kz1000r2
1983 KZ1000R
- peter1958
06 Jan 2017 14:05
One thing to look for on J model engines are dropped vavle guides. You can take the header off and shine a light in there to see if there are any that dropped. I had my head repaired by larry and he says that was a common problem . I see so much ‎Potential in that bike, Realy like the headers
www.kzzone.com/
- spdygon
06 Jan 2017 15:49
nice ....one sure to restore but you have alot to do my friend
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
1974 Z1 900 project
