Springer seat
  • Epicface803
  • Epicface803's Avatar Topic Author
Springer seat
27 Dec 2016 09:22
#750781
So I have a springer seat to put on my CSR 1000 and I'm having trouble visualizing how it should be installed I want to build a pan that still utilizes the original hinges and latch has anyone ever put one of these seats on and I need some ideas on what to do to make this look nice
  • davido
  • davido's Avatar
Re: Springer seat
27 Dec 2016 10:34
#750783
Having trouble picturing this. If its a springer seat ,it would be fixed/hinged at the front with the springs at the back. If its hinged at the side (One side) the springs would need be on the opposite side .Which would give for an 'Interseting'ride,Im sure. Going down a bumpy road,youre going to be bouncing around like a Weeble!
I understand that the OEM matress on a CSR is buck ugly but surely you can come up with a better solution? If you want to use the springer,maybe you can mount a front seat hinge on the rear tank mounting bolt? (Forget about the original hinges. Whack them off!) Failing that,just cut down the foam on the original seat or make a whole new seat and pan with fiberglass.
Good luck
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • stratman
  • stratman's Avatar
Re: Springer seat
27 Dec 2016 11:00
#750785
Adding onto davido's comments... Obviously, if you're going for a radical change and have your heart set on a springer seat, this won't help. However, my CSR seat was reupholstered by the previous owner and I think it was a major improvement over the original:
Attachment 81KZ650-2.JPG not found
I might like a little less overlap with the tank, but I'm pretty happy with it overalll.
Barry
1981 KZ650 CSR
