1980 Kz 750 e engine questins
- Kz750equad
16 Nov 2016 00:33 - 16 Nov 2016 00:57
So this is what I have going on right now I took the engine off a 1980 kz750e and put it on my 2003 kfx 400 and have a few questions
First question the two breather tubes on the top of the engine what can I all do them can I seal them off witch would be my number one choice cause I do nothing but ride in sand
Second question the breather that went to the bottom of the air box how do I properly plug that off or put a filter on it I wanna run pod filters
3rd question what jets should I run when I run pod filters I will be putting a custom made 4 into one exhaust going to a two brothers can
Fourth question how big of a nitrous shot can I put to this engine or is nitrous down right to much for the stock guts of the engine
Last edit: 16 Nov 2016 00:57 by Kz750equad.
- Nebr_Rex
Re: 1980 Kz 750 e engine questins
16 Nov 2016 02:32 - 16 Nov 2016 02:34
1] plug them
3] they make jet kits
4] the engine has cast pistons, I wouldn't unless it has an aftermarket big bore kit with lower compression pistons
pics?
pics?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
Last edit: 16 Nov 2016 02:34 by Nebr_Rex.
- Kz750equad
16 Nov 2016 02:47
Do you know a good starting point for the jets I am completely new to this. And I have the top two vents plugged off already I just don't have the bottom one under the carbs plugged yet
16 Nov 2016 04:43
The lower tube is a crankcase vent. Keep it open. Running it into a catch bottle or sticking a small filter on is the standard procedure for what to do with that when running pods.
No clue on jetting, that's why a jet kit was suggested. Dynojet makes the best because they come with new needles which affects the midrange.
If you haven't adjusted the valves on that engine you should do that before running it. The valves tighten with mileage and you will toast that engine straight away in the environment you plan to run if the valves are overly tight. I'd run some good synthetic oil in that thing too. Rotella synthetic is the best of the cheaper oils appropriate for that extreme environment.
Good luck and get some mufflers
- Nebr_Rex
16 Nov 2016 04:46
DynoJet has a kit for the KZ750E/H. A good jet kit is more than just the jets. They also include the needle a instructions,
As for the vent just clamp on a small filter.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Nebr_Rex
16 Nov 2016 05:09
And get rid of those filters[?].
Get some UNIs or K&Ns. The cheap ones restrict the air flow the air passages in the carb ventri
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- undiablo
16 Nov 2016 11:09 - 16 Nov 2016 11:25
KZ750 Jetting for PODs and 4 into 1:
Slow pilot jet #35
Primary main jet #70
Secondary main jet #140
Dynojet kit is another option.
As Nebr_Rex said, get UNIs or K&Ns. Or at least cut the rubber that blocks de air jet and diaphragm vent at the intake.
Slow pilot jet #35
Attachment CV34inletside.png not found
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
Last edit: 16 Nov 2016 11:25 by undiablo.
- Kz750equad
16 Nov 2016 15:16
Cool I will get those jets and filters yeah I just have those filters laying around And put them on so I could romp around on it I had to feel how quick it was And it definitely scares ya a little bit
16 Nov 2016 15:28
Murder quad. :ohmy:
- Kz750equad
16 Nov 2016 19:05
So your saying I prob should not shoot nitrous cause I have a 15 hp bump nitrous kit that needs to be put on something
16 Nov 2016 19:50
I'd bet you will get more than 15hp by properly sorting the carbs and installing proper exhaust.
- Kz750equad
16 Nov 2016 20:01
That's what size of valve I have on the kit right now I can get bigger I just don't wanna grenade that motor I know there's no really safe amount to shoot I just wanna know if anyone had shot nitrous threw it and what size they shot I don't wanna over do it.
